Show Printable Version 102 Likes Search this Thread
08-23-2010, 03:04 AM   #586
agsy's Avatar
TAv mode is absent from the Kx model.
08-23-2010, 03:58 PM   #587
QuoteOriginally posted by agsy Quote
Alas .....
08-24-2010, 03:51 AM   #588
thibs's Avatar
In low end models, forget about TAV, two wheels etc.
Now, if the K-r is targeted higher than K-x (I mean, in market segment), then it may inherit of some of these.
08-25-2010, 01:39 PM   #589
QuoteOriginally posted by thibs Quote
The theory, based on nothing other than a bit of thought, is that Pentax maintains the K-X as the low-end entry level. If that doesn't sound silly. At about its existing street price.
There is room, then, for USD $700-$850 K-R kit. Street price depends on its value in relation to competition. That is the high-end entry level. Perhaps aimed at (would-be) enthusiasts rather than budget-minded family memory keepers.
WR is a big unknown here but the addition of a new sensor, AF points, competitive video, perhaps improved SR, etc. would provide the justification for the higher price as well as provide justification for upgrade from K-X. And it's available in fuchsia with a black pommel and pale pink fender skirts.
K-7 continues to be marketed, at ($900-$1K) for those who like the sealing, size, handling, and still image capabilities. It's behind on ISO (from a competitive position) but it's the entry level for the outdoor niche interested still images. I'd suggest a 55-300 WR release to accompany this emphasis. Moderately-priced 17-70 WR would be an ideal complement but hardly likely. Think old-style Sigma (non-OS, non-HSM) with weather resistance rather than * sealing.
Then we have the wunderkind, K-5, at the top of the heap. Plenty of room for improvement over the K-7, as we read endlessly, and room, too, for the appropriate pricing at $1,600 (maybe) and falling to competitive levels.
If either of the new cameras find their pricing pushed too close to the older model, the older model drops again or (in the case of the K-7) vanishes entirely.
We'll look at this again at the end of this year.
08-25-2010, 02:06 PM   #590
Class A's Avatar
QuoteOriginally posted by glanglois Quote
I want bilious green dots on the pale pink fender skirts, please.
08-25-2010, 02:25 PM   #591
Fine, then. I'll throw in a pristine while crinoline underneath - give the guys a second thrill.
I wonder what Google translate would do with all of this?
08-28-2010, 08:16 PM   #592
Class A's Avatar
Dear Pentax,
please add acceleration sensors in addition to the gyro sensors so that you can measure camera displacement as well as camera rotation. This would be fantastic for hand-held macro photography.
If forward/backward moves could automatically adjust the focus that'll be brilliant but I'd be happy with just a compensation of sideways and upwards/downwards moves.
08-28-2010, 08:47 PM   #593
enoeske's Avatar
How about using face detection as well as several of the autofocus points closest to those faces to calculate the minimum aperture needed to get them all in focus? I would think that the camera could say, I need to focus here and remember the distance, and also I need to focus here, then use those two distances to look up a depth of field calculation for which aperture is needed.
08-30-2010, 03:27 PM   #594
I think we already have this. It is called Shake Reduction.
08-30-2010, 04:16 PM   #595
Class A's Avatar
QuoteOriginally posted by Jyrkira Quote
Shake reduction as implemented by current Pentax DSLRs only compensates for image blur caused by camera rotations. Gyro sensors measure the rotation and the sensor is shifted to counteract the resulting image blur.
This works well for non-macro photography but in the latter camera displacement shifts cause worse image blur than camera rotation so a different approach to image stabilisation is needed. Hence my suggestion to also measure camera displacement.
08-30-2010, 09:21 PM   #596
mattdm's Avatar
Dear Pentax,
You sure about that? As I understand it, the ability to compensate for rotational movement is new in the K-7 (see http://www.pentaximaging.com/slr/k-7); previous incarnations only did lateral shifts. The K-7 didn't trade out the lateral corrections for rotational ones — it now does both. At least, so says logic.
08-30-2010, 09:49 PM   #597
Class A's Avatar
QuoteOriginally posted by mattdm Quote
Yes.
Pentax DSLRs prior to the K-7 only compensated for shake caused by the following rotational motions: Yaw and Pitch. The K-7 added correction against "Roll".
No Pentax DSLR compensates translational motions, i.e., camera displacements that do not involve any kind of rotational component. If you put your Pentax on rails and moved it during exposure, it wouldn't be able to detect that motion as it only detects rotational movement, thus causing image blur.
That's fine for regular photography were pure camera displacement has negligible influence on image blur and rotational shake totally dominates. Think about keeping a laser pointer dot still at a far away wall; you better get the rotation of the pointer under control, rather than shifts that occur in parallel to the wall.
09-01-2010, 02:03 AM   #598
Alcazar's Avatar
Mmmh... istn't the laser pointer dot a circle? if you rotate a circle, nothing really happens...
i mean what you control IS the shifts that occur in parallel to the wall, any rotational shake you would not notice
or is there something i've misunderstood?
m
09-01-2010, 02:17 AM   #599
Alcazar's Avatar
- next to the "view"-button i'd like a dedicated button (or the ability to set another button to this, eg the raw-button) that let's me quickly do the single task that i do the most: zoom in to 100% to check sharpness. (1 pixel in image = 1 pixel of LCD, not something like 107.9% like it's now) Would be smart to zoom in on the area in the image where the focus point was selected to be.
- ability to switch off blurring when zoomed in more than 100% in view mode
- possibility to directly connect a portable usb hard disk to copy images to, without the need for a computer in between
- bigger, brighter, and focus-accurate viewfinder
- tethering
- possibility to switch off dark frame substraction
- iso below 100
- ability to choose exposure times longer than 30 secs.
- AF-button on the grip
09-01-2010, 05:36 AM   #600
Class A's Avatar
QuoteOriginally posted by Alcazar Quote
Imagine the circle is not red throughout but shows a pattern (as an image would do). Rotate the laser pointer and the pattern rotates. That's one source of image blur caused by camera "roll". That one isn't depended on the distance to the subject though.
The rotation I was really talking about occurs through the other two axes of the laser pointer and correspond to "yaw" and "pitch" rotation. You may want to call it "tilt" and "swivel"/"pan" in our laser pointer example. Small swings of the laser pointer will yield large movements of the dot on the wall. This is why shake reduction targets the "yaw/pitch (and roll)" rotation of the camera, rather than camera displacements.
battery, body, cable, camera, chicago, cubs, customer service, drive, fans, flash, grip, idea, kit, lens, pentax, photo industry, photography, power, release, relese, resistance, ricoh imaging, row, screen, shutter, sixteen, socket, suggestion, thread, units, weather
Dear Pentax About your lenses. offertonhatter Pentax News and Rumors 112 04-10-2012 03:44 AM
Misc Oh dear, oh dear, oh deer... Rense Post Your Photos! 5 11-05-2010 07:41 PM
dear pentax please be more careful anepo Photographic Technique 2 06-08-2010 11:43 AM
dear Pentax....... nathancombs Post Your Photos! 5 01-04-2008 11:17 PM
My Dear, Dear Friends: Don't Do This. Mike Cash Pentax SLR Lens Discussion 54 12-07-2007 11:08 PM
All times are GMT -7. The time now is 11:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
