09-21-2010, 02:40 AM   #631
Dear Pentax,
please give us manual control in video modes. Including manual audio levelling, manual gain/ISO and, if possible, manual shutter angle/shutter speed selection. And 24p for those who want it.
Also don't switch HDMI output resolutions around when switching to video recording. It breaks using an external screen. And increase HDMI output resolution to 1080p.
While we're on the topic of external screens: I wouldn't need an external screen if the internal screen swiveled.
And when I wanted you to improve the AF, I didn't mean just speed (thanks, though!). I meant "give me more points. smaller points. proper subject tracking with configurable lock-on time. prediction."
09-21-2010, 03:53 AM   #632
If not manual video controls then maybe something like this:
Flicker reduction function reduces the flicker effect that might occur under fluorescent or mercury vapor lighting while using Live View or D-Movie. You can select 50Hz or 60Hz, according to the local power frequency where you are shooting.
09-21-2010, 11:40 AM   #633
Banned
Dear Pentax,
I'm very pleased with the coming K-5 and all it's new future's. Please give us next to the 14-bit RAW the possability to make 12-bit Raw pictures. With this extra choice we can use the K-5 for sports and make 15 RAW in a single burst before the buffer fils up.
Thank you
Ron Hendriks
With the K-7:
09-21-2010, 03:22 PM   #634
Class A's Avatar
Dear Pentax,
please add tethered shooting to the K-5 with a firmware upgrade. The first version only needs to support the basic "shutter release" and "image transfer" protocol that Lightroom requires for its built-in tethered shooting.
What light does it shine on Pentax if the only two brands supported by Lightroom for tethered shooting are Nikon and Canon?
QuoteOriginally posted by Arpe Quote
...how about at least making [SR] activate when we press the AF button?
Great idea. This would help avoiding the "two finger -- one half-pressed" grip one has to apply to be ready for a moment.
It would be better if one could configure the camera to keep the SR ready until the camera shuts itself off but tying the "SR-read" event to the AF button would be the next best thing.
09-21-2010, 03:27 PM   #635
Arpe's Avatar
Exactly - I believe one of the other makes does this.
09-21-2010, 03:36 PM   #636
Having seen fujifilms x100 camera I hope that pentax too will develop one very similar with the electronic & optical viewfinder.
- Weathersealing
- Fast f2 interchangeable lenses: a wide, normal and telephoto.
- amazing dymanic range
- low noise sensor
- hd videos
But above all retro style
09-22-2010, 08:09 AM   #637
Sorry if this one has been brought up before but the idea just came to me. Wouldn't it be nice if one was able to use older flashguns by programming in the guide number at ISO 100 into the camera so it could automatically set the aperture based on the distance to the subject? What do you all think? It seems like this one would be easy enough to do in a firmware upgrade!
09-22-2010, 08:13 AM   #638
QuoteOriginally posted by roliver Quote
Sounds like a good return on investment oppertunity for Pentax...
09-22-2010, 08:18 AM   #639
Aristophanes's Avatar
QuoteOriginally posted by JoepLX3 Quote
Sounds like a good way to kill sales of new flashguns, reduce revenues, and drive the company into insolvency.
09-22-2010, 08:25 AM   #640
QuoteOriginally posted by Aristophanes Quote
What new flashguns?
09-22-2010, 09:50 AM   #641
please include user settings (and appropriate battery life warnings) for SR active time durations, including all the time.
09-22-2010, 10:57 AM   #642
I don't think so somehow... it's a bit like Pentax letting people use M lenses. Yes you CAN make them work but the stop down metering is a pain. It's the same with the flashguns. Even doing what I suggest would only provide limited extra functionality... there would still be a problem with zoom heads on the flashguns and also bounce flash wouldn't work this way either. Those two features are what I consider the only reasons for someone to buy a new P-TTL flashgun in the first place!
09-22-2010, 04:42 PM   #643
Arpe's Avatar
QuoteOriginally posted by RonHendriks1966 Quote
I think that's a good idea.
AND as Pentax now seem to be a much more capable sports camera, how about some sports lenses? For me a 70-200/2.8 with FAST AF (not SDM) and a compatible 1.4x TC is a minimum, it's a real workhorse of other makes (Canon makes 4 versions of the 70-200!), unbelievable that Pentax doesn't make one. At very least put out a 1.4xTC that's SDM and DC compatible that not only sports people want, then we can use Sigma's capable lenses.
09-22-2010, 06:34 PM   #644
mattdm's Avatar
]Dear Pentax,
I'm very pleased with the coming K-5 and all it's new future's. Please give us next to the 14-bit RAW the possability to make 12-bit Rawpictures. With this extra choice we can use the K-5 for sports and make 15 RAW in a single burst before the buffer fils up.
What would it do? Strip out the least-significant two bits on the fly as it puts the data in to the buffer? Where would it put the files while it's waiting to do that processing? In a pre-buffer?
Why not just make the buffer bigger?
09-23-2010, 06:27 AM   #645
WPRESTO's Avatar
Here's a really simple feature I'd value: an old-fashioned threaded cable release socket. The Fuji Finepix I purchased to experiment with digital before getting a K10 has such a socket in the shutter button, same as on uncounted thousands of 35mm cameras . Any mechanical release could be used, triggering both AF and shutter (just like pressing down with your finger). Electronic releases are fine, but they're expensive and can fail (my first Pentax unit has gone bad - won't trigger the AF). Mechanical releases are available by the score, cheaply, in a variety of lengths. I have units, used on the LX, ranging from 4 inches to 40 inches, although 8~12 inch is most useful. I even have a 10 foot pneumatic release that works reasonably well (not as reliable as a cable).
battery, body, cable, camera, chicago, cubs, customer service, drive, fans, flash, grip, idea, kit, lens, pentax, photo industry, photography, power, release, relese, resistance, ricoh imaging, row, screen, shutter, sixteen, socket, suggestion, thread, units, weather
Dear Pentax About your lenses. offertonhatter Pentax News and Rumors 112 04-10-2012 03:44 AM
Misc Oh dear, oh dear, oh deer... Rense Post Your Photos! 5 11-05-2010 07:41 PM
dear pentax please be more careful anepo Photographic Technique 2 06-08-2010 11:43 AM
dear Pentax....... nathancombs Post Your Photos! 5 01-04-2008 11:17 PM
My Dear, Dear Friends: Don't Do This. Mike Cash Pentax SLR Lens Discussion 54 12-07-2007 11:08 PM
All times are GMT -7. The time now is 10:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
