I'm very fond of my Pentax K-1, but just can't find my way with the rear screen display. If you don't browse the info button to switch it off, which require nothing less than 5 button press, the rear screen automatically switch off and on at each half-press on the shutter release button of when focusing with the AF button, which is very disturbing (was the case on my K-3 too).
So please Ricoh, could you consider the following usability options in the Menu (which would ideally be implemented in recent bodies through firmware update) :
- Auto switch/off of rear screen
If enabled, the rear screen will enter the No display mode (and will remain so) once you half-press the shutter release button or the AF button. It could also be done by having a long press on the Info button (0.5 to 0.7s will suffice). To switch back to the last used display mode (be it Settings, Levels or Electronic compass), the user will have to have a long press again on the Info button. It also means that the No display mode can be removed from the display mode, to save one button press when cycling the modes. The switch off would occur on_button_release. That's an important fact regarding point #2. - Cycle Display modes with front wheel
If enabled, press the Info button at least 05-0.7s, keep it pressed and cycle through the display modes with the front wheel, without displaying the Display modes sub-window, to select a new mode. This will also let the user check levels or compass and go back to the Settings display rather quickly without too much button press.
