If you repeat yourself, i will also have to repeat.
THIS IS NOT ABOUT YOUR SKILLS THAT MAY BE GOOD, NOR IS THIS ABOUT A FEW END RESULTS.
Pls be polite and stop reposting your pictures that dont say anything about the AF-behaviour of any Pentax DSLR.
We all know the restrictions of our AF-system.
Especially if one had the guts to
seriously(- that includes reading the manual and use the cam for longer then 5min.) try some other system with up to date AF...
Even if you post a hundred of your photos, that will not change the facts.
(One cant "
convince" hardware to work better, forget that. I also tried no success)
So it may be only 12fps at 42mp with nearly perfect AF-tracking, that are possible at the moment(Sony a99II-...spare yourself to refer to mirror speed restrictions -> D5...)to offer reasonable priced products, (the big makers that sit on a widespread userbase, better do well to keep one up their sleeves)
nonetheless that is not the point here.
AGAIN LOUD AND CLEAR: THIS IS NOT TECHNICAL DISCUSSION.
So again:
If you say:
Yes thats for me!
Give this Idea:
+1 from me
good idea
appreciate this.
or something alike
If you say:
No i dont like the idea, I would rather like to have 42Megapixels but therefore only 3fps burst and a smaller buffer. And the same AF system as in the predecessor flagship or only slightly better.
Then give this idea:
-1
dont like the idea.
no, I dont like it.
.... Discussing around about
: "what if, inbetween, workaround, c'mon s'ain bad" was not intended when i titled the thread:
Petition for Significantly Better AF and Faster Bursts Instead of Megapixel-Madness
