Originally posted by Ascencio Canon and nikon friends don't need cactus to use Godox thats my point. I think the part your leaving out is you also put the godox trigger on top of the cactus trigger. Maybe i can post some pictures.
K-1 is a great camera with probably the best image quality for landscapes but don't minimize the lack of lighting support for whatever reasons
yes... i already wanted to warn you,
that i dont know what clackers told you, because he is on my ignore list,
but to me it looked like there was a misunderstanding going on.
To me it looks like, somebody who reads, what you may have repeated from mr. clackers in a question:
Originally posted by Ascencio So when you use your godox strobe the only thing on your camera is the cactus trigger for HSS. If so how did you set that up?
...must come to the conclusion, that a GODOX flash would work with Cactus transmitters "out of the box", what certainly is not true, and clackers for sure did not want to imply...
(sry but in the end it comes out like this.)
maybe you want to edit your former answer to mr clackers... so people dont go off and buy Cactus V6II transceivers and AD600Bs with the straight belief, they would get a working solution without the GODOX triggers.
since that is cleared up, and you already mentioned that one has to put the godox trigger on top of a cactus transceiver to get that to work (if it works!!!!)
Let me ask you, have you already tried that piggyback solution by yourself or has anybody else some experience with such a setup?
Because despite X-TTL beeing available already or not, one thing that should already work with the current firmware on the Cactus V6II, if you put a Godox Nikon trigger(X1T-N) on top
(and set the flash system on the cactus transceiver to "Nikon"),
...should be HSS!
That was, what my question actually was about; Sry, I may have expressed myself a little bit "vague" at first, because I may have been in a hurry.
If you tried the same with a Godox trigger for Canon cameras(X1T-C), I am pretty sure some people would also be interested in the results of this experiment.
