Show Printable Version 7 Likes Search this Thread
04-30-2019, 09:39 PM - 1 Like   #16
Wheatfield's Avatar
You're potentially paying for it twice, though, Luftfluss - glad money is no concern for you!
You have the choice if not buying it. I kind of like the idea of having a stable viewfinder for long lenses. And it’s not like as if they aren’t already making stabilized lenses. They know how to do it.
04-30-2019, 09:40 PM   #17
Otis Memorial Pentaxian
clackers's Avatar
QuoteOriginally posted by luftfluss Quote
The cost of ILIS development and manufacturing would be amortized over the course of much equipment, and we're talking about in-lens stabilization for longer, more expensive lenses, so the additional cost would be a small percentage of the overall cost of the lens.
Well, you've admitted it costs more, Luftfluss, but contradicted yourself when you said that would be amortized - which means spread over a large number of items, when you say it would be for only a small number of 'longer, more expensive lenses'.
It also puts constraints on the lens designers. There's now a group of elements that has to be moved by a gyroscope.
Olympus touts their hybrid sensor-lens image stabilization, as they make lenses with stabilization... so no, they don't "do it all in the camera".
Well, that's wrong. The newest Olympuses do it all in camera, they're not hybrids. That's why you can even use adapted Leica or whatever lenses on them and get the advantages, just like Pentax.
04-30-2019, 09:50 PM   #18
clackers's Avatar
As said before, I already have it in my Bigmos … and, 'meh', it's overrated!
Sure, they're already in a couple of very expensive 645 lenses, but that's a system without IBIS.
05-01-2019, 08:44 PM - 1 Like   #19
pentax360's Avatar
Forget that I think the next Pentax flagship should have an aerospace grade gyroscope.
05-02-2019, 08:12 AM - 1 Like   #20
luftfluss's Avatar
Can't believe I'm responding, but...
What do you think the "IS" in "M.Zuiko ED 300mm f4.0 IS PRO" indicates?
05-02-2019, 10:49 AM   #21
Wheatfield's Avatar
I found the Bigma to be over rated.
One can say that about any feature. I believe we used to say that about useful autofocus because it wasn’t something we had. Shake reduction of any form can be said to be over rated if one shoots off a tripod all the time.
I have, on occasion, used a friend’s Nikon with a VR 70-200/ 2.8. The steady viewfinder was quite nice.
There is no reason for the binary either/or thinking in this case.
05-02-2019, 05:21 PM   #22
clackers's Avatar
That $2400 lens will work very well with Olympus and Panasonic bodies that don't have IBIS. Remember, with Pentax, even the entry levels have it, this is not true of other brands.
But since 2012, there have been Olympus models that offer in themselves five way IBIS.
You can see for yourself Olympus' comparison of IBIS vs ILIS … Olympus - Olympus Australia
05-02-2019, 07:46 PM   #23
I might be slightly confused? If you go to the lens page with the 300mm, Olympus mentions how their lenses with IS work in conjunction with their 5 axis IBIS. it is not a one or other, although you can select which one you want to use. It is only with select bodies, but it does work well.
05-02-2019, 09:08 PM   #24
clackers's Avatar
QuoteOriginally posted by Fcsnt54 Quote
Possibly. Have a look at the table 'Advantages of the in-body image stabilisation' in the Olympus page.
That particular lens' ILIS will work in conjunction with IBIS, but the table shows clearly having the stabilization in the body's better, especially with other lenses.
Where it *would* make beautiful sense is for video, until Pentax find a way to go back to mechanical rather than electronic IS.
05-03-2019, 05:57 AM   #25
Oh, ok... That makes more sense. Yeah I don't know how often they update the information as they don't make mention of the newer bodies from the past couple years. So I can see how they just mention how ibis is still the way to go.
I was thinking of another point as you mention video. If Pentax would develop a CO system where the cameras can utilize both at the same time, would it be worth it outside of just looking at the back screen for video? Reason I ask is if one was to do a long exposures without a tripod it would be difficult to keep the camera steady while looking at a blacked out viewfinder. There would be nothing to be able to keep the framing for reference. I can see it if it was one or the other as far as long lenses, but in general it might be a waste in that regard.
05-04-2019, 09:06 AM   #26
It's too bad one of the fundamental advantages - that being a stabilized viewfinder doesn't work with an SLR system, which Olympus isn't. Which is exactly the point - if you're shooting in a sub 100mm range all the time, yeah, IBIS is better by a long shot. Once you get into 300+ area that jittery viewfinder gets old pretty quickly, so having even a rudimentary in-lens stabilization simply for the viewfinder would make the experience far more enjoyable.
customer service, lens, ricoh imaging, sr, suggestion
k 50 shake reduction shake jacques Visitors' Center 6 10-17-2017 11:07 AM
In Lens Shake Reduction zapp Product Suggestions and Feedback 2 07-10-2017 08:42 AM
K5 II video shake mechanical or electronic shake reduction? Rice Pentax K-5 & K-5 II 3 06-14-2014 02:51 PM
Shake reduction setting for reverse lens stacking macro mythguy9 Photographic Technique 11 01-25-2014 06:44 AM
All times are GMT -7. The time now is 10:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
