Originally posted by StiffLegged
Back to reality: a 14-stop dynamic range from a 14-bit sensor (at best) is how Pentax and the rest describe their sensors' sensitivity. Third-party measurements broadly confirm that.
And this is more or less a coincidence, not forced by 14bit by any means. The numbers look very similar and the dynamic increase was pretty linear to bit increase in the past decade, but there is absolutely no proportionality or linearity between those two quantities, unlike some people keep telling in forums until it is considered common sense.
---------- Post added 03-16-20 at 01:58 PM ----------
Originally posted by stevebrot That would be sort of hard to do without evaluating ranges to bits.
Do you understand how a bit bandwidth works? Because it does not make any sense at all to conclude the bit per ev from that.
The conversion works perfectly fine as long as you go for more than 4bit. Digital processing in this high resolution has no missalignment issues as there were 30 years ago with digital circuits.
