Originally posted by dlh It doesn't need to be a specialty item for photography. As long as the diameter, tip and ring numbers are correct for that camera, any commercially available extension cord will do.
Originally posted by whammerhead I'd be grateful if you were to post that. TIA
Originally posted by bertwert Give me a few days here, I'll see if I can find the materials to construct a new one and do a photo-guide with construction...
Sorry guys, couldn't find stuff to make a new one... but I'll try my best to explain here, if you have any questions, feel free to ask.
To start you need a 2.5mm stereo jack (they're not as easy to find as 3.5mm jacks but can be had online with no problems). There will be three connections on it; ground, focus/exposure, and shutter. I can't remember which is which, but it's fairly easy to work out using a bit of wire. Then use a three strand wire (or four, and you only need to use three of them), and connect each strand to a different connection on the jack. The wire can pretty much be any length you like. On the other end you need to connect one push button between the ground and shutter wires, and the other between the ground and focus wires. There you have it. You can make the end look nice if you like, mine was just soldered directly to the buttons and wrapped in copious amounts of electrical tape...
