06-25-2020, 07:15 AM   #1
Pop-Up Flash release button
On my K5 IIs the Pop-up Flash can be released whether the camera is ON or OFF. In my opinion the pop-up flash should only pop up when the camera is ON. I never had a problem with the flash popping up in my camera bag(so far), but I do think about it. Also the housing for the flash should be made sturdier to match the body. This is the only "flimsy" part on the K5 II and it sticks out like a sore thumb.
06-25-2020, 11:33 AM   #2
It might make the mechanism even more complicated to have a lock on it that moves when the camera is off!
06-25-2020, 05:56 PM   #3
swanlefitte's Avatar
The battery compart will open when turned off too. I guess it could have a slide press like the battery compartment. My camera will also turn on when not turned on. That does happen in my bag, it goes to standby, but might keep going live. The flash probably has without me giving it a second thought.
07-03-2020, 01:47 PM - 1 Like   #4
On the K-5IIs the button is mechanical; simple and reliable.
Some cameras had an electronic release button. I'm not exactly a fan of that design.
The problem was solved in the K-3II, K-1, K-1II as well as on the upcoming APS-C flagship
07-07-2020, 03:58 PM   #5
Otis Memorial Pentaxian
QuoteOriginally posted by hjoseph7 Quote
Perhaps it is just the design of my bags, but it appears this problem might have been addressed in the K-3. I have not had an accidental release in the last six years. The button requires a fairly definite press (releases at ~3/4 inward travel) and the spring is not weak.
07-07-2020, 04:05 PM   #6
Yes, true enough...all the more reason to own a Godox TT350P.
camera, customer service, flash, k5, pop-up, pop-up flash release, ricoh imaging, suggestion
Using a of camera third party flash with pop up flash GregYoung Pentax K-3 4 11-30-2016 09:39 PM
Flash doesn't pop up when pressing on button k-30 Sauler Troubleshooting and Beginner Help 2 05-03-2015 04:54 AM
Flash Bouncer for Pop-Up Flash? lawsonstone Pentax DSLR Discussion 13 01-07-2014 02:19 PM
K20D pop-up flash doesn't pop up! ducdao Pentax DSLR Discussion 3 11-29-2011 07:57 AM
K2000 - Pop up flash will not pop up. tkindred Pentax DSLR Discussion 6 08-17-2009 08:54 AM
All times are GMT -7. The time now is 10:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
