Originally posted by pres589 I also have some doubts about how much the cost would change between a full-frame and a crop-only lens from Pentax. And I don't think there are many easily comparable examples to draw from; maaaaybe maybe the 50-135 vs 70-200? DA 35 Ltd vs FA 35? I just don't think the added material costs are great enough to really figure on much of a difference in street price. I'd want to see some real numbers if there's a suggestion of more than 10% increase in cost. The money is in the engineering, marketing (ha), and a general 'what do you think we can get for this thing on the street?' valuation.
The difference would be in a different optical construction. While at e.g. 50mm, the DA50/1.8 and F50/1.7 and at 35mm the DA35/2.4 and FA35/2.0 (6 elements in 5 groups, 1 aspheric, f/2.0) are basically identical, because of a moderate field of view, the difference in angles steeply increases with shorter focal lengths (see e.g.
Bildwinkel (f) Brennweite - log/lin | Es gibt immer wieder D? | Flickr), requiring a lot more difficult corrections. A 24mm lens for APS-C needs to be corrected for a similar "easy" field of view as 36mm on full frame, so the complexity is moderate, except for very fast lenses. On full frame, the angle is comparable to the DA15mm (8 elements in 6 groups, 1 aspheric, 1 ED, only f/4.0) on APS-C - which by today's standards will be considered barely adequate with its pronounced quirks even at f/4.0. So I would expect a significantly more complex construction for a full frame lens at 24mm, with more special glass elements, higher element count and larger elements, requiring stronger AF motors - all driving up the cost.
