Originally posted by Ski Jumper Would someone have a lens hood suggestion for an A-20mm? Thanks in advance!
The original hood for the A series 20mm f 2.8 was a MH-RB67. If you want to attain historical accuracy you can keep your eyes open on ebay etc. for one of these.
Otherwise any screw-in or clip-on ultra wide angle hood will do as long as it is designed for the 67mm thread. Some of the collapsible rubber ones are quite good (and cheap) and they can be multi-purpose.... ie fully extended for a 50mm lens and partially for a wider one.
If you are using the lens on an aps-c camera you can get away with a hood designed for a longer FL.
