Show Printable Version 6 Likes Search this Thread
03-06-2017, 10:51 AM   #1
Why Pentax KP? Para que la Pentax KP? Situation solved - Situacion resuelta :-)
Talking about Pentax new camera KP. For what is need a reflex camera, with who is necessary to follow four steps, including the ignition, to shoot the first photo. Nothing matter if "instant view" are disable in its general settings menu? 😲
A propósito de la nueva Pentax KP. De que sirve una cámara reflex en la se necesitan seguir cuatro pasos, incluyendo el encendido, para disparar la primer foto. De nada sirve desactivar la "vista instantánea" en su menú de configuración general? 😲
Well, for skip this situation, no work in "M" (Manual option) and use personal settings in C1, C2 or C3...
Bueno, para escapar a esta situación, no use "M" (Opción Manual) y use configuraciones personales en C1, C2 or C3...
03-06-2017, 10:53 AM   #2
What four steps are you referring to? The basic shooting steps for the KP are the same as other Pentax bodies.
03-07-2017, 05:27 AM   #3
Welcome aboard!
If you have never used a single lens reflex camera I think I see what you are talking about. I have used these cameras for some 45 or so years now. I like being able to see exactly what the image is going to look like when I take a photograph. Even when using the old film rangefinder cameras I always had to be aware that what I was seeing and what the film was seeing were slightly different. And it got worse the closer the subject was to the camera. Plus you could not see what affect the lens depth of field would have on your image.
I am not a fan of electronic viewfinders. They just don't look right to me. Some cameras have a problem where the image you are seeing lags a bit behind exactly what is happening in front of you And if you are wearing polarized sun glasses there is quite a bit of loss of detail,
I also own a Pentax MX-1. Great little camera. But the only way to see what you are shooting is to look at the display on the rear of the camera. On a bright sunny day that is a problem. It is barely visible and I find myself looking for a shaded area to shoot from. Adding polarized sunglasses adds to the woes. And since I need to wear glasses taking them off is not an option.
So in summary I prefer the single lens reflex design. It is the most accurate way for me to see exactly what my image is going to look like. But it also means that it the image turns out bad it's my fault and i cannot blame the camera. Reviewing your photographs is a great way to learn humility. But by studying your failures and learning why the image failed makes you a better photographer.
03-12-2017, 06:16 PM   #4
This is no true! I was the first owners in Sweden the some Pentax from K-10. The best advantage was to be the first camera more fast to shoot in the digital photography... Until Pentax K-7, was very useful the lens from Sigma, try to use a Sigma 150-500/5-6,3 HSM DG APO for Pentax in this KP and see the electronical crisis that happen...
03-12-2017, 07:56 PM   #5
QuoteOriginally posted by ZeaFoto Quote
Is slow AF the issue? The time from startup to the camera's first shot is otherwise just a second or so.
03-12-2017, 10:06 PM   #6
reh321's Avatar
I don't understand. You need to be more specific.
(1) what steps are different for KP than for earlier Pentax camera?
(2) "electrical crisis"??? No one else has said anything about this. Please point us to details.
03-13-2017, 04:02 AM   #7
and the Kp whispered why not???
03-20-2017, 05:03 AM   #8
From K-3, Pentax cameras have troubles with the Sigma 150-500/5-6,3 HSM DG APO for Pentax. With this Pentax KP, the camera blocking for himself with electronic crisis, also in manual function with this Sigma lens :-(
Try it, please and share your experience with us, please.
03-20-2017, 12:57 PM - 1 Like   #9
"Until the K-7" the Sigma 150-500mm f/5-6.3 HSM DG APO was very useful- is your statement. So you are talking about all Pentax DSLR models since the K-20D, nearly 10 years back. The K-7 was the next flagship model after the K-20D.
I think the title of this thread should be- "Has anyone had trouble using the Sigma 150-500mm HSM DG APO on a Pentax DSLR?"
Then go on to explain exactly what "electronical crisis" you have experienced, and on which Pentax camera model this has happened.
Many of us use various Sigma lenses. The only issue coming up to speak of recently has been certain Sigma lenses having a problem, only with the full frame K-1, fitting onto the camera without some damage, requiring the lens to be modified by Sigma.
03-20-2017, 01:22 PM   #10
Talvez estas teniendo alguna dificultad con su Sigma, la cual es notorio un problema con el motor SDM que sufren estos lentes..le recomiendo llevarlo a un centro de servicio, o en defecto, comunicarse con Sigma directamente, estoy seguro que le resolveran..tambien puedes considerar convertir su lente a screwdrive, para que el motor de af de la misma camara mueva el lente,en el caso que le sea imposible reparar su lente.
04-26-2017, 01:11 AM   #11
Focus peaks
This is not a matter, Pentax say that new KP are better in compatibility, than previous ones of their digital cameras, also with lens from K-1000
Sigma still working very well from Pentax K10 to 7. In K3 and K3 IIs, works, but in manual focus and some troubles.
KP make existential electronic crisis, as short circuit, why? Is impossible to use then, without cover with plastic tape, the backside of his bayonet.
Unbelievable that focus peaks not works, when video are running. More worse, the definition of the screen turn blurred, limiting the possibility to follow subjects by manual focus. This is truly horrible for any modern camera and his price...
Peaking focus in digital technology, when cameras offer Live View and Video, are indispensable...
I use it, also from the time of Videotapes old cameras as Betacam, for example... There have not excuses, also cellphones and compact cameras doing it...
Here, the forum seems as Chorus Line of Pentax...
04-26-2017, 01:40 AM   #12
Sandy Hancock's Avatar
Pentax has absolutely no responsibility to maintain backward compatibility with third party lenses, especially old ones.
The KP is an excellent little crop DSLR.
04-26-2017, 04:15 AM - 1 Like   #13
I just ordered one.
04-26-2017, 06:46 AM - 3 Likes   #14
shiner's Avatar
It's the coolest Pentax ever. Most fun I've had snapping photos since the K-01
04-29-2017, 12:12 AM - 1 Like   #15
It is the issue with the Sigma lens not working with the KP. Please contact your local Sigma agent and get them to help. You may need to have the firmware on the Sigma lens updated.
camera, kp, para, pentax, pentax kp, reflex, why pentax kp?
Godox Ving V850 para Pentax jorge2014 General Talk 3 07-11-2014 06:54 AM
Manual em portugues para Pentax K7 Tchuni Visitors' Center 4 09-29-2011 03:14 PM
Que esta sujetando este chico ? MANCLUB Pentax Camera and Field Accessories 6 12-31-2010 11:27 AM
La araña que cae / The falling spider hahifuheho Post Your Photos! 2 11-25-2008 03:51 PM
All times are GMT -7. The time now is 07:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
