Thanks, Jones. Yes I know how the AF works. The F2.8 was intented, deeper DoF certenly helps, but I would like to blur the background by a little and get sharp faces. If my subject is a face I can't choose more contrasty target sadly. And zooming out after focusing changes the focus plane too, so I can't do that neither.
Originally posted by caliscouser I learned anecdotally on my other camera bodies is the center focus point is bigger than you think.
Thanks, caliscouser, this helped me. The KP has 3 F2.8 luminance flux AF point, so I will try the upper one. Now this is not the edge, like on my K-30. I messured the size of the center point and yes, you are right the background is in the area. I hoped some more intelligance from the AF system. It would calculate the center with more weight in the phase matching. (Of corse it could make other issues.)
Originally posted by Clarkey From the manual, page 62, it looks like you can reduce the size of the AF area
This is true for Live View only. And yes live view may solve my problem, but I am a viewfinder shoter, and live view is slow and consumes more power. I keep this option as a my last fallback.
Rawr, trust me I am an engeneer.
I was designed algorithmys for medical imageing (X-ray tomosynthesis), I've detected cancer by AI.
To make the AE and AF system a little more clear here is how a basic system works:
The auto exposeur sees the same image as you through the viewfinder by a little 86k image sensor similar to the main sensor in the camera. In spot metering and center weighted average the metering is only a weighted average of the pixel values. (It may do it per chanel.) In matrix metering this weight matrix is modified by many parameters - like the selected AF point. It can do face detections and advanced scene analysis by deep neural networks for example. But this calculation is independent of the AF system - wich uses the same AE sensor and the same source image. The AE sensor can help the AF system by selecting the AF point in tracking mode. Because it sees a video through the viewfinder it can track the lateral movement. The AF sensor only sees the depth.
So the 86k sensor is common, but the metering mode does not affect the AF algorithm and only a few AF parameters affects the metering like the selected AF point.
