I'm gonna start looking into this. Discovered today that the generic L Plate I use for my K-1 (which I modified slightly so that I can access the battery compartment fine) doesn't actually work very well at all with the KP. I mean it works, it fits nicely, you just can't open the battery compartment. In practice I think I won't find it a big deal, it's not hard or tricky to unscrew the L plate slightly, pan it around and swap the battery and then replace back.
The issue is that the battery storage opening compartment takes up a far larger area of the base, it's about a full 1/3rd, and the KP being quite small in the first place does make for a challenge for manufacturers.
Really the L plate needs to be more like a ∟(where both sides are approximate the same length). Perhaps filing a L Plate down will work, I'm gonna have a hunt about...
EDIT: I think the cheapest option would be to grab a MPU105 L Universal Quick Release Plate, where the screw doesn't run length ways along the plate but has a choice of holes spanning width ways, like so;
Move screw, cut away plate that blocks the battery compartment, file and smooth down cut.
