07-07-2017, 07:54 PM   #1
Defective battery or defective camera?
Just bought the KP on Wednesday. I'm returning it to B&H on Sunday because of a defective battery. Actually, I don't know if the problem is the battery or the camera, but anyway on a full charge I only got about a dozen shots before getting the "battery depleted" warning. Granted, I was using the menus a lot to set the camera up, and I used Live View a bit also, but I can't believe I drained the battery that fast. Has anyone else noticed weirdness with the battery?
I'm also returning it because for some reason mine only came with two grips, and no hex key to change them. I thought all three and a hex key were supposed to be included...
07-08-2017, 07:15 AM - 1 Like   #2
twilhelm's Avatar
It does sound like a defective battery. I've had old batteries display similar issues as they are dying.
07-08-2017, 08:57 AM - 1 Like   #3
Not a Number's Avatar
Check the shutter count. It could be a previously returned camera.
07-08-2017, 12:04 PM   #4
That happened to me when I bought my K5.
07-08-2017, 03:38 PM - 1 Like   #5
It could be either. I had one Pentax DSLR body years ago that started eating battery power. It was repaired under warranty. I think you were right to return it for exchange. B&H will probably simply send you another and figure it out afterwards. They are great to deal with. In the box should be one grip on the camera- the small size, then the other 2 sizes as well, along with the little allen wrench.
The smaller battery used with the KP does run low much faster than that of the K-5. Same story with other smaller Pentax DSLRs, like the K-S2 which I also own I know since I also use the K-5 IIs.
I bought my KP from B&H and have been happy with their service and delighted with the KP! Just be sure to order at least one extra battery and put a full charge on both. I have also noticed the smaller battery can eventually weaken if left stored in the camera for a length of time. Much less noticeable if doing so with the K-5.
07-10-2017, 03:12 PM - 1 Like   #6
Wingincamera's Avatar
My KP (from B&H) came with the three grips and hex key.
battery, camera, hex, kp, pentax kp
Defective user or defective K-50 RedSky Troubleshooting and Beginner Help 17 06-18-2016 04:39 PM
Defective Pentax D-BG4 Battery Grip Docrwm Pentax Camera and Field Accessories 10 12-24-2011 02:46 PM
Defective Camara or Battery Problem K200D?? ganarask Pentax DSLR Discussion 13 02-14-2010 03:27 PM
Are one or more of my lenses defective? Is it the camera? Or is it me? rpriedhorsky Pentax SLR Lens Discussion 4 06-04-2009 08:33 AM
blown out reds...is my camera defective? nicekato42 Pentax DSLR Discussion 18 03-06-2007 02:42 PM
All times are GMT -7. The time now is 05:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
