Originally posted by richard70 I tried a factory reset to rule out any settings I might have erroneously applied, unfortunately it was still the same.
However stevebrot your reply has led to a solution, although previously EV was set to zero, dialling in a negative value is giving me consistent results. It seems on the KP they're linked (EV) for both optical and LV where you say they are separate on the K3, but I can live with that. I always thought that in Manual mode that the EV would be reset, but it seems that once you've added a value it remains... so I'm down to a single metering click prior to releasing the shutter which is great.
Thanks for your help.
It is a great feature of Pentax that it memorizes EV. That way everybody can tune to his personal preferences (some do exposure to the right, others don't, ...). And if you don't like it, you can set it, such that the camera doesn't memorize. Also when you use a flash in manual mode, it is a great feature. Green buttom will always consider the dialed in EV setting. It is these little tricks, why I like the Pentax product.
I use many (# > 10) "old" on the KP (K, M, A, adaptall from Tamron, trioplan and have not run across a problem. The new SR is great.
