Originally posted by Adam Well the shutter itself is a lot smaller, so that makes a lot of sense. Also, I believe the KP has a more advanced ES system, with fewer limitations on when it can be used.
Wow, yes indeed it does, what a pleasant surprise. Here's what I have discovered thus far when trying to set up a 'Church' mode, or basically any set up that involves making the least amount of noise possible;
KP
- I'm using TAv mode and some ETTL (fyi)
- ES on
KP can do this with ES on that the K-1 can't (if I'm not mistaken);
- perform incredibly quiet, almost dead silent, if you are using MF then its practically stealth mode.
- can use ES in conjunction with AF.C!
- can use ES outside of LV mode, ie use it with LV off and use OVF!
- can use burst mode!
SR is still off however when using ES, no way of getting round that. I also noticed that when using my DFA 100mm, the AF noise the KP makes during focusing is far higher than the K-1 makes with the same lens attached. However, using the KP with AF in ES mode with the aforementioned lens, if I actually lock onto a subject, then I can burst 5-10 shots of easily and all registering dead silent! Whereas the K-1 would 'click' during each and every bursting shot.
Damn... that's impressive. If I could find a good longer focal range lens that AF silent, then pairing that with the KP would be a wicked Church combo!
