Show Printable Version 18 Likes Search this Thread
11-22-2017, 04:31 AM   #1
KP battery life improvement
Here's a suggestion for the first firmware upgrade for the KP:
Add an option (as was available on my K-5) to set the LCD display default to always OFF, so it only powers on when "INFO" or "PLAY" buttons are pressed.
I'm happy to use the viewfinder display to check my camera settings, by not powering the LCD every time I switch on or press the shutter button I'm sure the battery life would be much improved.
11-22-2017, 04:34 AM   #2
Can't you already do that by double tapping info and selecting the "off" icon in the flyover menu?
11-22-2017, 11:47 AM   #3
Yes, you can do that - mine is off by default
11-23-2017, 03:45 AM   #4
Well that's great news. I had looked through the manual (but not in depth I must admit) and hadn't spotted that, thanks for the info!
02-25-2018, 05:03 PM   #5
"Can't you already do that by double tapping info and selecting the "off" icon in the flyover menu?"
Of course you can, but that doesn't set Off as a default. The info display comes back on when you turn on the camera. Needing four button presses to turn it off each time is annoying. I wouldn't mind so much if the battery wasn't so pitiful.
02-25-2018, 05:59 PM   #6
Its a little like carrying an extra clip of ammo- I just carry one of those tiny batteries fully charged in a pocket and don't worry about it if the one in camera should run low. Even two extras wouldn't pose any problem.
But I do agree that there should be a quicker control to shut off the LCD screen. Sometimes, once I have my settings, I'd rather not have it on as it can be a distraction.
02-25-2018, 07:58 PM - 1 Like   #7
Ex Finn.'s Avatar
Say what? my KP remembers "display off" setting as a default. I do have preview enabled but I could disable it also.
02-25-2018, 08:11 PM - 1 Like   #8
Ex Finn.'s Avatar
Memory, page 2, "shooting info display"
02-25-2018, 08:18 PM - 1 Like   #9
Ex Finn.'s Avatar
As far as battery life, D-Li90 in the D-BG7 is your friend.
02-26-2018, 11:49 AM - 1 Like   #10
MJKoski's Avatar
Yes, D-LI90 makes KP about 1000% more useful in normal winter conditions.
02-26-2018, 12:55 PM   #11
QuoteOriginally posted by Ex Finn. Quote
Im new here. What is a D-BG7 ?
02-26-2018, 12:58 PM   #12
Digitiser of Film
BigMackCam's Avatar
QuoteOriginally posted by HelenJo Quote
It's the optional battery grip for the KP It provides a shutter release, control wheels and buttons to allow easier use in portrait orientation, but also allows you to use a higher capacity D-Li90 battery to power the camera... the same battery used in the K-3II etc.
https://www.bhphotovideo.com/c/product/1313279-REG/pentax_38589_d_bg7_battery_grip.html
02-26-2018, 01:13 PM   #13
https://www.bhphotovideo.com/c/product/1313279-REG/pentax_38589_d_bg7_batter...981&
Thank You. It should have been obvious , Im just not used to model designations yet.
02-27-2018, 07:48 AM - 2 Likes   #14
You do then need the charger as well for the larger capacity D-Li90 battery, which is not a given when you have no other Pentax lying around...
I bought an extra D-Li109, which brings battery life up to K3 level with the batterygrip on, and lends you the flexibility to leave an empty battery behind charging. Only really heavy shooting would benefit from the D-Li90 in the batterygrip.
Chris
02-27-2018, 08:02 AM   #15
Digitiser of Film
BigMackCam's Avatar
QuoteOriginally posted by Chris Mak Quote
Good point, Chris - I hadn't thought to mention that
battery, display, hint, info, kp, kp battery life, lcd, life, memory, page, pentax kp
comprar una KP o pasarme al formato compreto (Buy a KP or switch to the full format)? mariovidal Pentax KP 5 06-29-2018 05:45 AM
Why Pentax KP? Para que la Pentax KP? ZeaFoto Pentax KP 16 06-14-2018 08:53 AM
Battery life Pentax KP niels hansen Troubleshooting and Beginner Help 25 11-22-2017 12:54 AM
Suggestion for improvement hamidamin Pentax K-1 & K-1 II 2 02-06-2017 02:31 AM
Longest battery life models - Preferably AA battery and waterproof. cadmus Pentax Compact Cameras 8 07-04-2016 08:33 PM
All times are GMT -7. The time now is 05:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
