Originally posted by eruizmiro Interesting. It could be a battery issue. Usually, I use LV for low angle shots with the help of the tilt screen, or just to get an idea of the end result before hand. Given your answer, I wonder if I was using one of the generic batteries I bought recently to complement the Pentax one that came with the camera. I'll check. Thx.
Let us know how it turns out.
I do like the articulated screen on the K-S2 for really low or really high hand held shots and use LV for those the rest of the time I prefer/ use the VF.
Originally posted by Ex Finn. Interesting. Sounds like a lot of corrections are taking place.
I try to avoid any "in camera processing" because of the lack of processing power.
I do very little in camera processing as well. It cuts down on my battery charge as does LV. The main reason tho is I don't like using the small camera screen for such things. I prefer my monitor it is a lot larger ( Obviously ) so I can see thins a lot better plus my processing software is better. Only thing I do in camera is to occasionally change to a B/W filter.
