Originally posted by reh321 I'm still in the salivating stage - I haven't located enough loose money yet to purchase a KP - but do tell me, how far can you push the ISO level and still get a good SOOC image?
I have not tried any extremes yet. And a lot depends on what degree of perfection one is looking for. I have not encountered objectionable noise (for me) even if I am shooting a roller-hockey game using JPEGs at ISO 6400! And this is with the camera's default auto NR setting. So I know I am getting at least one stop+ improvement over my already very good K-5IIs! RAW images with the right processing would be even better. But this is one thing that is great with the KP- it is capable of producing exceptional results, even right out of the camera!
There may be others here who can provide some extensive high ISO images, or some can be found in another thread.
---------- Post added 01-03-18 at 06:37 PM ----------
I just did a couple of test shots and of course I can see some noise in shadows at ISO 6400 without any post process, and just JPEGs, but not bad. And is the same any better at ISO 3200? Yes, in fact looking quite good at that! If you want to see the difference yourself, just go to the imaging resource website- just google imaging resource Comparometer, a feature they offer where you can compare the same image taken with one camera against another. Just JPEG images right out of the camera at default settings. You can compare the KP against the K-3, for instance. If you want to compare a discontinued model, you have to first select "all cameras" at the top of the column.
Once you select the cameras to compare, you'll find the only shots taken with the KP so far are the ones of the still-life having the various objects, at various ISO settings.. So with the other camera you'll have to scroll down to get that still-life shot. Then click on the ISO image you want for each camera. Then click on the image again when it comes up to get maximum blowup. Now you can move around within the image. One good place to compare is to the far right, the shadow areas between the paint brush in the cup and the Samuel Smith bottle. Then check both the writing on the Samuel Smith bottle, as well as the figure on the Hellas bottle to see how detail has been preserved or lost.
