Originally posted by TXPentaxK50 I get what you are saying as to focusing on the face, but that’s hard to do when you are trying to get their whole body into the frame in 1/500th of a second.
I do think i will stop down to 3.2 and bump ISO to 6400 if I need to - by most accounts the KP is high ISO superb.
I also didn’t realize there was a sharp / fine function in the custom image menu.
Why would turning off Shake reduction help the cause, as someone suggested? That seems counterintuitive.
Thanks everyone !
---------- Post added 01-09-18 at 10:32 PM ----------
All good questions! I believe I selected highest quality for jpegs. I don’t believe I changed any parameters, other than I went full Manual and just went with 2.8/3200 and 1/500 shutter.
Yes, following action is hard. Your 1/500 sec shutter should be easily adequate for volleyball. I keep SR on, since I am moving the camera a lot, using the half-press like crazy for pre-focusing as much as possible, knowing who has the puck, but not when he will shoot, which happens very quickly! That's when my speed in firing, and my 1/500 sec shutter speed, come into play. If you have a good idea who will receive the ball and will be responding, the idea is to try to get a quick pre-focus on the face in this case, since it matters not much if the ball is blurred. One has to be quicker than quick, in manipulating the equipment, constantly reframing with your zoom, etc. That's why it takes practice. The more experience, the better you'll become in doing it. I think you did well for a first outing.
As to the sharpening adjustment in the Custom Image menus, you access them via the quick-link info button. The Custom Image menus is the first section- hit "ok" to open up the section. The "Bright" category is the camera's default setting. Click info again to open up its menu. In this category, contrast and sharpening are up by +1 by default, which is fine. Tab your controller's down button to the bottom "S" settings and use your thumb dial to implement "F" by the "S" for Fine Sharpening. You are done- hit "ok" to return to all categories. Using your controller's right button, move to the next category- "Natural". In this case, the S default is mid-point, so increase it to +1 with your controller's right button, then using your thumb dial again, implement the "F" by the "S" for Fine sharpening. Leave contrast as is. You are done- hit "ok". Then use your controller's left button to put your camera back to the "Bright" default setting, unless you are happier to leave it on "Natural" for skin-tone in your people shots. I don't see anything wrong with the skin tone you've been getting, they don't look too red or over-saturated, but that is a matter for you to determine. Then hit ok again for the all fast-links screen and turn off the camera, or just turn it off.
