Site Supporter Join Date: Dec 2016 Location: Southeastern Michigan |
If this were "customized" to be progressively even more bulky, it would be back to a K-5/K-3 bulk- so then what would be the point of the KP design in the first place?
I've used the K5, then the K-5 IIs for years. Wonderful ergonomics, for me at least. I still do, but not as much. Since acquiring the KP, it has become my most-used model. I don't find the position or style of the e-dials, or the grip(s) to be an issue. Yes, different than other models, but still well-designed. When I am holding in a shooting position, with my rear thumb in the thumb groove, my front trigger-finger falls upon the front e-dial naturally, or if it is up around on top, it rests upon the shutter button. No issue at all. No problem going back and forth. It is simply a matter of acclimation from what one is used to. If am using the small grip, and with my trigger-finger on the e-dial, the compactness does put my fingers closer to each other than with the usual DSLR bulky grip, but the vertical e-dial has a bit more of the dial exposed making it a bigger dial than most, and I don't find it hard to use at all. It has enough resistance to make it unlikely to be accidentally nudged. Some prefer to always use the KP's largest-size grip, which is still not all that large, because it does separate the trigger-finger more, and it provides a deeper purchase compared to the small-size grip.
The optional battery grip, which I also have, provides plenty of grip area, as well as plenty of battery capability. With it installed, the weight of the camera is still only about 3 oz. over the K-3 II body alone, plus the extra battery. If another of the small batteries is chosen, which weighs next to nothing, this would still double the shooting capacity over the KP itself. The only thing then still missing is the middle finger notch of the usual-style grip, which allows a more bowling-ball grip security. This omission is to prevent reaching your finger to the e-dial and shutter button from becoming awkward. Since the battery grip is optional, this allows the user to configure the design according to current needs.
Coming from ye olde classic film cameras, which invariably had the shutter button up on top, this transition was easy for me. Of course, they had no front e-dial. But ye olde shutter speed dial was also up on top, next to the shutter button. To use this dial one had to reach over from the shutter button, and to do it properly also had to employ the thumb from the rear, while still holding the camera. After some 6 years with the normal manual-only SLR, there was a technical advancement which we now call the Av mode. I then got my first Pentax- the ME Super. I could select an aperture by using the lens aperture ring, as normal, and by selecting"auto" on a dial atop the camera, it would automatically set the shutter speed! Wow!! was my amazement. But I could also take it off "auto" and select my own as before, but now there was no room for another dial on this amazingly compact metal-body camera, so it was done via two buttons instead- one for up,the other for down, with the shutter speed displayed in the VF. So you had reach your finger over the shutter button to find the up & down buttons, while looking through the VF. To me it was easy, and didn't require my thumb like ye olde dial did. But years later, in two AF SLR models, Pentax returned to ye olde shutter speed dial- the ZX/MZ-5(n) and a more modern such dial on the MZ-S, containing an LCD screen.
So if anyone who requires a bulky style body grip, containing both a front e-dial and shutter button, in a 35mm film body, I highly recommend the very large-bodied Pentax PZ-1p (or Z-1p). The main difference is the shutter button is below the e-dial. This, I think, is also the most advanced Pentax 35mm AF body in many ways, except the AF, which was fast, but had just one sensor that was not sensitive to horizontal lines. It came out in the mid-1990's and was the predecessor of today's Pentax DSLR designs. it was mystifying to me that Pentax then went backwards in those two subsequent ZX/MZ models.
