05-21-2018, 02:39 AM - 1 Like   #76
BigMackCam's Avatar
QuoteOriginally posted by panonski Quote
dear Big Mack Cam,
I know everything that you post already.
But I simply want more scientific measuring.
If I put on my wristwatch some rubber, and hardly taped it with plastic band,
does that mean it's weather proof ?
NO.
No, you're quite right, it doesn't mean it's weather proof.
But if that wristwatch has gaskets between the back and the case, the glass and the case, around the winding stem, and a screw-down crown, that means it's more weather resistant than a watch that doesn't have those features.
I've worn a 300m water-resistant watch while scuba diving and had that suffer water ingress. It happens. It wasn't water proof - just water resistant.
05-21-2018, 02:44 AM - 2 Likes   #77
Man With A Camera
Racer X 69's Avatar
dear Big Mack Cam,
does that mean it's weather resitance ?
NO.
For such claim, there should be facts behind, and you know - FACTS ARE - SCIENTIFIC REASEARCH AND MEASURING
Perhaps you should contact Ricoh Pentax directly and ask them for the data you are so insistently demanding.
Surely they would be the one and only true source.
05-21-2018, 02:44 AM   #78
panonski's Avatar
I edited my post,
to be more accurate.
We can all agree that Pentax claims on Wheater Resitance could be, and could be not - the true.
Such claim is useless, and can lead to damage your camera, because you were naive enough to believe that.
that's why we have a forum comunity
---------- Post added 05-21-18 at 02:47 AM ----------
QuoteOriginally posted by Racer X 69 Quote
I dont want to - or should I say - I don't need too... For me is enough what I read from here, and from my experiance too.
Camera is not good sealed, specially in flash hot shoe, and I don't believe anymore in WR.
05-21-2018, 02:47 AM - 3 Likes   #79
BigMackCam's Avatar
I edited my post,
Right. And I do agree that Ricoh's advertising claims present the value of weather resistance rather optimistically. That's the part I have a problem with - not the level of weather resistance, which I know is far better than for non-weather-resistant cameras - but the marketing aspect which is far too bold.
05-21-2018, 02:50 AM - 2 Likes   #80
panonski's Avatar
yes, exactly that ... We finally have right words here
05-21-2018, 03:26 AM - 5 Likes   #81
volley's Avatar
I am not sure if Pentax ever published the level of protection according to the IEC standard 60529 (IP Code, Internationally Protection Marking). My guess is it might be IP53.
But then again, in all fainess, these codes are typically suited as an acceptance criteria during final inspection of goods. You might want to check the test specifications, but these are difficult to translate into "real life" conditions.
Especially when users (like us) interfere with the integrity of the product ... in other words are changing lenses
At the end of the day it is mainly marketing and I would consider it as "a design with many seal should be better than a design without seals". In reality I dont treat WR lenses and cameras differently than non-WR equipment. Both should work under "normal" circumstances and that includes some moderate rain or snow of course.
05-21-2018, 03:29 AM - 3 Likes   #82
MarkJerling's Avatar
I've shot with my K-5 in the pouring rain many times. The camera is, undoubtedly, weather resistant. We've seen heie rinse his camera under running water. Clearly, (most) Pentax cameras are reasonably water resistant. If I had a KP, I'd expect it to be able to handle a bit of rain and if it did not, I'd expect Ricoh to repair it to ensure it was weather resistant. I don't think that's an unreasonable point of view.
Certainly, in our jurisdiction, under our consumer laws, if a company advertises a product as being weather resistant and showed that product in marketing materials complete with water droplets on and around the product, then I would be able to go to court and win on the basis that the item is not fit for purpose in that it's clearly not weather resistant if it fails when a not unreasonable amount of moisture comes its way.
I can understand the OP and some others frustration with this issue. Either the OP's KP is a defective product and he should be able to have it repaired at no cost to him, or, Ricoh needs to remove their weather resistant advertising materials and not make claims about the weather resistance of their products, if the purchasers of those cameras cannot expect weather resistance.
After all, what is "weather"? By definition, that should mean some rain, snow, wind, fog, humidity etc should be fine. I agree with Mike. The marketing department should not make claims that the production or design departments cannot match.
05-21-2018, 10:16 AM - 2 Likes   #83
Otis Memorial Pentaxian
QuoteOriginally posted by MarkJerling Quote
What is getting tiresome is the same old voices expressing the same old gripes (copy paste?). Perhaps we could create a sticky with the most common comments and leave a reference to it when threads like what this has turned into are quite reasonably closed.
05-21-2018, 10:19 AM - 1 Like   #84
Man With A Camera
Racer X 69's Avatar
I concur.
act, battery, camera, consumer, contracts, damage, grip, issue, kp, law, pentax, pentax kp, pentax wr, post, proof, shame, watch, water, weather, wr
KP vs K-70 - to KP or not to KP, that is the question OldChE Pentax DSLR Discussion 28 11-02-2019 05:29 AM
Misc Help! Mike has gone mad! newmikey Post Your Photos! 2 10-02-2013 11:28 AM
K-5 II SR gone crazy - shakes the sensor like mad and blurs the image Quazimoto Troubleshooting and Beginner Help 11 06-26-2013 04:45 AM
Pentax Optio W90 gone mad, or maybe I`m stupid WillyBeemen Troubleshooting and Beginner Help 7 10-27-2011 06:48 AM
Can Someone Please Explain To Me Why London Has Gone Mad? magkelly General Talk 78 08-14-2011 09:11 AM
All times are GMT -7. The time now is 10:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
