03-14-2018, 08:47 AM - 1 Like   #16
bkpix's Avatar
I agree with the careful tripod-test chart method here. But I'll also suggest you don't need to be so formal.
You can simply sit down outside on a sunny day (giving you very high shutter speed) and photograph a scene, with the lens wide open, that includes a detailed object (could be a traffic sign or license plate) at the distance you're most interested in optimizing for. Zoom in to 100 percent on the LCD to see how it looks. Then try an adjustment of +5 and -5 and photograph the scene again. That will give you a notion of which way to go. Then gradually close in on the setting that gives you the sharpest result.
After the first or second iteration changing the settings becomes second nature, so it goes quite quickly. Further, you can't harm anything. If you screw it all up, just put everything back to zero and try a different method.
Works very well for me.
03-14-2018, 05:08 PM   #17
QuoteOriginally posted by bkpix Quote
... at the distance you're most interested in optimizing for...
A good point worth highlighting. Some zoom lenses require different adjustment at different focal lengths and for different subject distances. Most lenses work decently all around if you adjust for the middle of the zoom range and at a normal subject distance, but some need extra attention. I have one lens in particular that requires extra adjustment when the subject is within three feet, so I just dial it in when I know I need it.
af, calibrate, calibrate my lenses, camera, focus, inch, kp, lens, lenses, methods, paths, pentax kp, plane, search
KP vs K-70 - to KP or not to KP, that is the question OldChE Pentax DSLR Discussion 28 11-02-2019 05:29 AM
What lighting conditions do you do to calibrate your lenses? LeDave Pentax SLR Lens Discussion 3 07-30-2012 12:04 PM
Can anyone help me calibrate my new MacBook Pro 13" Screen? Student Troubleshooting and Beginner Help 4 02-08-2011 12:45 AM
Anyone calibrate a hand-held meter? Wombat Film SLRs and Compact Film Cameras 4 11-06-2010 06:09 AM
Anyone calibrate a MacBook monitor? jmdeegan Digital Processing, Software, and Printing 3 04-18-2008 11:17 AM
All times are GMT -7. The time now is 04:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
