Show Printable Version 13 Likes Search this Thread
04-03-2018, 10:33 AM   #16
The KP, like the K-3 II, does show some algorithmic improvements when shooting moving subjects. In other scenarios isn't essentially the same as the K-3.
04-03-2018, 10:36 AM   #17
panonski's Avatar
Flux rate from KP is 2.8, while on K3 is 5.6, or ?
04-03-2018, 10:46 AM   #18
Otis Memorial Pentaxian
QuoteOriginally posted by panonski Quote
yeah, I know that trick, but when I do portarits, - I want bokeh
...and the eye glint in focus...without having to do anything...
04-03-2018, 10:48 AM   #19
panonski's Avatar
yes, exactly that
04-03-2018, 10:50 AM   #20
Flux rate is a strange term.
As with all SAFOX 11 bodies, both models have three detectors with f/2.8 focus sensitivity in a vertical row at center with the rest being f/5.6.
04-03-2018, 10:53 AM   #21
The sensitivity of the hardware itself is the same for both the KP and K-3.
04-03-2018, 10:59 AM   #22
panonski's Avatar
so K-3 have also 2.8 flux rate ?
04-03-2018, 11:02 AM - 1 Like   #23
Yup.
04-03-2018, 11:13 AM   #24
panonski's Avatar
Yup.
and Pentax said it's a new thing in KP
04-03-2018, 11:17 AM - 5 Likes   #25
Let's say - the time changed Norm, the time changed
What has not changed is the need to know the limitations of gear and apply that to one's technique. There are cameras on the market that will nail focus on an eye* every time, but not using PDAF and even the best PDAF systems will not nail focus on anything consistently at maximum apertures much wider than f/2.8.
A few comments from another "old guy"
  • If one cannot use manual focus as a back-up, even for action, there will be a ton of shots simply missed **
  • Using manual focus is an essential skill, sort of like figuring exposure, calculating flash, and reading instructions
  • Deep manual focus experience helps one understand what may be expected of auto-focus
  • If one depends on the camera to find and attain the intended plane of focus, one will seldom be happy with the camera. The camera does not read minds.
  • An awful lot of serious portrait work is done with AF turned OFF
  • An awful lot of seriously good portraits with incredible bokeh are done at apertures capable of returning both ears and eyebrows in acceptable focus (repeat five times...there will be a test)
  • An awful lot of aspiring pros are lazy and seriously deficient in basic skills and knowledge
  • Pixel peeping leads to overspending on gear
Of course, I am a little biased, having done most of my photography since the late 1960s without AF or even programmed auto-exposure.
* Pity if it's the wrong eye or the wrong face
** I have shot bicycle racing with the K10D in low light long after the Canon and Nikon guys packed it up for the day. I even got a few keepers.
04-03-2018, 11:20 AM - 1 Like   #26
They pretty much always say the AF is new in every press release
But the specs and reviews don't lie.
04-03-2018, 12:44 PM   #27
IBIS is really nice to have for primes and legacy glass. Lens optical stab helps a lot for AF acquisition and tracking. The best is to have both IBIS and optical stab., but that combination isn't widely available.
04-03-2018, 12:53 PM   #28
normhead's Avatar
And I'm sure their engineers can quote measurements to demonstrate it is, I think you have to jump a models or two to see it. If you use a K20D then a K-3 you will be mightily impressed at the progress. (And then sell your K20D because you don't like it any more.
So in the next release of an APS-c flagship, K-1, K-3ii, the next model, maybe you'll be able to pick that up and say "ya this K-3 really sucks" Let's discuss this in 2023, by then the slow incremental change might be noticeable.
04-03-2018, 01:58 PM   #29
Thanks for noting this obvious advantage to OIS when shooting hand-held.
04-03-2018, 02:31 PM - 2 Likes   #30
So, the bootom line, is I'm very well awared of limitations in AF , that can be tricky in shooting.
My K3 behaviour in AF-S is very incosistent... from 10 shoots, spotted on the same AF target place - several of them would consider well focused, after that, several would be slightly out of focus - and maybe one or two in best way would have maximum sharpness...
Of course I'm talking about shooting and focusing throught the mirror - or shooting with OVF ...
Results in AF vary to much for my personal taste, and that's not a so good thing, when you have exscesive shooting of model, or more of them, and later in desktop you find out - that most of the pics, are - well - slightly out of maximum sharpness, while some of them reach that level.
I read in Kp official Ricoh page, that KP has a new SAFOX 11 AF module, with lower apperture pass at 2.8, vs older version which is only 5.6....
Pentax statements here are :
" SAFOX 11 New-generation AF sensor module with a high-speed algorithm
The PENTAX KP incorporates the high-performance SAFOX 11 AF sensor module in its autofocus system. This dependable module features a diffraction lens to effectively compensate for chromatic aberration and assure pinpoint focus on the subject, even under adverse conditions such as when shooting against backlight or photographing high-contrast subjects.
High-speed AF algorithm
This latest autofocus algorithm assures a faster autofocusing speed than the one used in the conventional SAFOX 11 module. It lets you react more swiftly and effortlessly to unexpected shutter chances."
Features4 | PENTAX KP | RICOH IMAGING
i WOULD LOVE TO SEE SOME REVIEWS FROM KP USERS HERE..., specially from ones who are still engage with older K 3 or different bodies
Thank yOU ALL
I share your experience with the K3 auto focus behavior. I no longer have the K3, but used it for four years with the DA560, and worst was initial focus acquisition. When there was little time for a single shot, I would aim, focus and shoot, and often the focus would be just off, or sometimes even far off. When abundant time to pamper the shutter button, I could also get a reasonable amount in focus, but many shots would often still have an amount of blur. I am not alltogether sure though, if it was only the AF inaccuracy leading to slightly blurred shots. It may also be sometimes due to SR or shutter shock, even if that should not be the case with shutter times like 1/500s.
Now with the KP, everything feels much more secure, less buggy, more confident. That also goes for AF. Without doubt, focus is more responsive and faster with the DA560, but also hunts less around the subject, something which my K3 did a lot, many small corrections, and although too early to give any solid opinion, I already trust my KP much more than I ever did the K3.
Energy supply seems much more stable: even on a nearly depleted battery, the KP still performs exactly as with a full battery. My K3 would start acting up on a battery less than half charged: fits of unresponsiveness out of the blue, irratic misfocussing. Not all the time, but it does indicate, that stability was not my K3's forte. The KP feels much more "high end" to me than my K3 ever did.
So to me, Ricoh/Pentax is on the right path with the KP. I hope they advance further.
Also, experimenting with the electronic shutter, that automatically disables SR, I find that many shots have less blurring. I hope Pentax will also get access for the next APS-C body to a sensor with faster readout time to make the electronic shutter more practical.
Chris
af, af module vs, algorithm, autofocus, kp, kp safox af, module, pentax, pentax kp, safox, safox af module
KP vs K-70 - to KP or not to KP, that is the question OldChE Pentax DSLR Discussion 28 11-02-2019 05:29 AM
K-5 vs MZ-S vs LX vs PZ-1p vs ist*D vs K10D vs K20D vs K-7 vs....... Steelski Pentax K-5 & K-5 II 2 06-28-2017 04:59 PM
For Sale - Sold: Ricoh GXR body A12 M module A12 28mm/2.5 Lens Module ddhytz Sold Items 4 06-01-2013 05:53 AM
Different between Safox VIII+ and Safox IX? vcheng9 Pentax DSLR Discussion 53 03-13-2011 12:01 AM
All times are GMT -7. The time now is 12:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
