Well, I know what 70 is like- been there and done that, but I wouldn't mind going backwards to it! It is the way you feel and what you can do that counts. You'll be making a huge jump by going to a KP, and with a little acclamation, you will be very impressed- just get an up-to-date, quality lens! As others said, you cannot take advantage of many, many features of what you are buying with the old manual lenses on it.
First do an assessment of the focal lengths you mostly use, and this will give you a clue as to a lens to consider. Also, remember that the design of the KP very much favors a compact ensemble. It does not have to be so, but my point is, take advantage of what the body offers. When using a modern lens, don't shoot in the"Green" Auto mode, use the "P" mode if you want fully automated exposure. And, be sure to go into the Custom Image menus to implement Fine Sharpening.
For an all-around use zoom lens, these come to mind: the DA 20-40mm DC WR f/2.8-4 Limited. This lens represents the optimum the KP was designed for. Extremely high quality build with WR, but compact. Very fine imaging.
For a lot more zoom range, the DA 18-135mm DC WR f/3.5-5.6 is amazingly compact for such a zoom range, has very good to excellent imaging, very well built, and offers very fast, accurate, quiet AF. It can keep to f/3.5-4.5 out to 70mm.
Then for a super-compact prime to complement the zoom lens, the DA 15 MM f/4 Limited is incredible.
You could add a DA 50mm f/1.8 for low light work, and for getting an extra shallow depth of field as a fine portrait lens. It is not costly.
If you need something special like fast f/2.8 zoom lenses, that is a whole other discussion. For instance, the DA* 50-135mm is top notch, and compact for what it is, offering a similar field of view as a 70-200mm f/2.8 on a 35mm film body like the K-1000.
I am a good bit beyond 70, but I bought a silver/black KP last year and liked it so much, this year I bought a second body!
