08-04-2018, 06:43 PM   #1
helios 44-2 M42
Hi, All:
I just received my 1972 Russian USSR 8 blades KMZ Helios-44-2 58mm f2 lens, I paired it with Pentax KP. I was so looking forward to try the King of crazy Soapy bobble bokeh lens, to my disappointment, my copy produced only Hexagon shaped bokeh ( please see photos), not the soapy bubble bokeh. could any one please sheds some lights on Why i got the Hexagon and How to achieve the soapy bubble bokeh. wander if there are different kinds of way to use the lens?
any comment will be greatly appreciated
Thanks
CooperPete
PENTAX KP  Photo
PENTAX KP  Photo
08-04-2018, 06:53 PM   #2
retired sw engineer
reh321's Avatar
QuoteOriginally posted by CooperPete Quote
Hi, All:
Thanks
CooperPete
I see 8-sided bokeh - not hexagonal - which is what you should get with an eight-blade iris
08-04-2018, 07:05 PM   #3
Shoot wide open f2. Bokeh takes on the shape of your aperture, stopped down you will get the shape of your blades, wide open should be soft and bubbly
08-04-2018, 09:01 PM   #4
As said above - that is stopped down, if you are leaving it at f2 then check your adapter isn't pushing the pin in a bit.
08-05-2018, 02:09 AM   #5
Senior Moderator
BigMackCam's Avatar
As others have said, you need to shoot wide open. Choose a background that has plenty of highlight details and position yourself so that your subject is roughly half way between you and the background. Also note that when using the lens on an APS-C sensor camera, a lot of the swirl is cropped, so whilst you can still achieve some amount of swirl, it won't look as extreme as it does when shooting full frame.
QuoteOriginally posted by sqrrl Quote
The 44-2 is a preset lens, so there's no aperture pin to depress.
Make sure that the preset ring is set to f/2, and the diaphragm control ring is set so that you see a perfect circle when looking through the lens.
08-05-2018, 02:53 AM   #6
Right you are, I was thinking of the 44m
bokeh, bubble, helios 44-2, hexagon, kp, lens, pentax kp, soapy bubble, swirly
Helios 44 silver 13 blades vs. Helios 44M-7 Cabessius Pentax SLR Lens Discussion 3 07-31-2018 08:05 PM
Which Helios-44 produces the best "swirl"... 44-2, 44M & 44M-4 tested BigMackCam Pentax Lens Articles 11 02-05-2017 11:34 AM
Helios 44-2 (Гелиос-44-2) 58mm f2 preset 8 blades ducdao Pentax SLR Lens Discussion 5 04-25-2010 06:15 PM
What does the 44 stands for if anything, on the Helios 44-2? ismaelg Pentax SLR Lens Discussion 2 03-01-2010 02:05 AM
For Sale - Sold: M42 Helios 44M-6 MC 58mm F/2 & Helios 44-2 58mm F/2 donTTouchonlywatch Sold Items 6 12-25-2009 02:16 AM
All times are GMT -7. The time now is 10:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
