Originally posted by rogerstg "Expands the dynamic range and enables a wider range of tones to be recorded by the CMOS sensor and reduces the occurrence of overexposed/underexposed areas."
The description is a bit misleading in that the dynamic range is not actually widened; doing that would require multiple exposures (HDR). While the full details are not known with any certainty, highlight/shadow correction appears to be done primarily by applying up to one stop +/- exposure compensation using sensitivity shift with additional tweaks being applied to in-camera JPEG output. Since the behavior is somewhat unpredictable, it is common practice when responding to poor exposure help requests on this site to suggest setting both to "OFF" when doing troubleshooting.
