03-16-2019, 10:29 AM   #1
Spodeworld's Avatar
Pixel shift question
Was wondering if there is an increase in dynamic range by using pixel shift or if it provides additional headroom for post processing.
Thanks
03-16-2019, 11:50 AM   #2
This means a full RGB value for a pixel location can be created without having to interpolate from neighboring values.
PIXLS.US - RawTherapee and Pentax Pixel Shift
Explains all the details very well
03-16-2019, 05:07 PM - 1 Like   #3
I've come across several article that touch on this.
Conclusion - In conclusion, the K-1 gives one of the best Raw dynamic range results we've ever seen, when shooting in single shot mode and absolutely outstanding results in circumstances where you can use the pixel shift mode. The multiple sampling of the same scene effectively gives a 2EV dynamic range boost, meaning it out-performs both the D810 and the 645Z by a comfortable margin. Less noise (though multiple captures) and multiple 14-bit values at every pixel mean it can give outstanding levels of DR for static scenes where you can use the Pixel Shift mode.
Then this site, provides a set of excellent examples of non PS vs PS across several post processing utilities and discusses the differences.
Then there are some sites discussing that PS potentially meeting and exceeds Medium Format dynamic range.
03-17-2019, 02:41 AM   #4
K1N8's article is a pretty good summation. To me, it increases color depth the most, but it does decreased noise in the shadows. If you use it at higher isos, I think the noise reduction can be profound. It does add about some dynamic range in that I can bump shadows quite a bit more with a pixel shift image than I can with a straight K-1 image without having artifacts and unwanted noise show up in the final image.
kp, pentax kp, pixel, pixel shift, shift
Pixel shift with pixel artefacts Dericali Pentax K-1 4 07-18-2018 12:57 PM
Lloyd Chambers Prefers Pentax Pixel Shift To Sony's Pixel Shift Fenwoodian Pentax K-1 2 07-16-2018 02:15 PM
Pixel Shift Question - splitting RAW files? GalacticPhoto Pentax K-70 14 03-22-2018 04:29 PM
K1/Samyang 24mm Tilt/Shift and Pixel Shift DDoram Pentax K-1 3 06-25-2016 02:05 PM
Another pixel shift question re movement Oakland Rob Pentax K-3 2 02-18-2016 11:45 AM
All times are GMT -7. The time now is 01:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
