10-18-2019, 03:56 PM   #1
KP AF Mode button does nothing
So when I press and hold the AF MODE button and rotate the front/rear dials in Program mode, the dials change the aperture and shutter speed as usual. When pressing and holding the AF MODE button, it should switch AF MODE, right? I wonder if it only works in certain settings/modes?
I sure wish Pentax could produce an intelligable user manual!
10-18-2019, 04:04 PM   #2
Pressing the button alone does nothing. You need to turn the opposite dial to change the mode, AFAIK. In other words, one dial controls the points, and the other the mode (AF.C or AF.S).
10-18-2019, 04:53 PM   #3
QuoteOriginally posted by JMeyer Quote
It was described in page number 60 of the manual. You have to turn the front and rear e-dials while pressing the AF mode button to make a change.
10-18-2019, 05:06 PM   #4
Ex Finn.'s Avatar
It is thorough but Japanese to English leaves some space for interpreting.
10-18-2019, 05:13 PM   #5
UncleVanya's Avatar
I'm confused. He mentions pushing the button and tiring the dials but says it isn't changing modes just aperture and shutter speed. That's wrong - right? Maybe broken button?
10-18-2019, 05:57 PM   #6
Ex Finn.'s Avatar
I am in the P-mode most of the time. Pressing the AE , front dial changes modes, rear dial changes focus points, at least on my KP
10-18-2019, 06:05 PM   #7
Ex Finn.'s Avatar
So, when you push the button, does the rear display change? If not then a possible hardware problem.
10-18-2019, 06:36 PM   #8
QuoteOriginally posted by parinya-ekparinya Quote
Yes, I am pressing and holding the AF MODE button while turning the e-dials, front and rear. I think I understand how it's supposed to behave. But what happens is: the e-dials change the shutter speed & aperture as they would without pressing down the button. (I almost always shoot in PROGRAM mode, if that makes any difference.)
Maybe it is a faulty button?
---------- Post added 10-18-2019 at 06:38 PM ----------
QuoteOriginally posted by Ex Finn. Quote
No, the rear display doesn't change. I'd expect it to highlight the AF field, but it doesn't.
This isn't a customizable button, right? I was wondering if I'd disabled it by mistake.
10-18-2019, 07:24 PM   #9
Mikesul's Avatar
Perhaps, I misunderstand the problem but the AF mode button is on the left side of the lens mount on the front of the camera. When you press that and rotate the front dial you will change AF.S/AF.C. The rear dial will change the focus point. Are you, perhaps, pushing the AF/AE button on the rear of the camera?
10-18-2019, 07:25 PM   #10
monochrome's Avatar
The rear LCD should display the current AF Mode and should change when pressing the AF Mode button on the left side of the mount If the AF Mode selection has not been reassigned. See Page 60 of the User Guide
The AF Mode can be assigned to C!, C2, or C3 from the Menu | Camera | 5 | > | AF Mode and would then be controlled - when the Custom Function is selected - by turning the Smart Function wheel (third wheel). See page 105 of the User Guide.
10-19-2019, 11:09 AM   #11
scc
Which lens are you using?
10-20-2019, 04:40 PM   #12
This may be a silly question, but it's worth asking just to be sure:
Is the AF switch set to AF or MF? Also, are you using an AF lens, and if you are, are you sure that it's working properly (e.g., the contacts are clean and the lens is mounted correctly?)
Upon checking my KP, I can see that pressing the AF button while an AF lens is mounted but the focus switch set to MF will still allow me to change AF point mode, but when using an actual manual focus-only lens, no matter what position the switch is in the AF button will have no effect. So, the simplest way to troubleshoot my suggestion is to check if your display shows "MF" and not "AF.C" or "AF.S", while making sure the switch is set to AF. If that is the case, and you're sure you're using an AF lens, then you probably have a contact issue. If not, then the button may be faulty.
10-20-2019, 07:19 PM   #13
Sorry for my misunderstanding.
A faulty button should be rare, but I guess that is possible.
10-20-2019, 09:08 PM   #14
bkpix's Avatar
Sounds broken to me.
10-20-2019, 09:14 PM   #15
Sandy Hancock's Avatar
Do you really have to press *AND* hold the button? I think press and release is all I have to do. I'll check when I get home....
af, af mode button, button, change, dials, display, e-dials, front, kp, kp af mode, mode, pentax kp
KP vs K-70 - to KP or not to KP, that is the question OldChE Pentax DSLR Discussion 28 11-02-2019 05:29 AM
KP bug or KP Broken, Av Mode and Red Blinky Warning Text in LV BruceBanner Pentax KP 26 06-25-2019 05:06 PM
Does anyone try the video mode on KP? wl02356427 Pentax KP 25 04-12-2019 03:19 AM
Question: is the KP AF in s-af mode better than the K3"s? Chris Mak Pentax KP 17 11-14-2017 06:03 AM
K3 AF micro-adjust does nothing??!! RedBoomer Pentax K-3 & K-3 II 12 12-07-2016 11:50 AM
All times are GMT -7. The time now is 08:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
