Originally posted by pschlute The DA* 300 is one of the sharpest telephotos made by Pentax. Unless your lens is a bad copy, you have focus issues.
I suggest the following:
1. Check the lens by focussing using a tripod in LV zoomed 100%. If the image is in sharp focus you know your lens's optics are OK.
2. Do a robust test using PDAF on an unambiguous target. Make the lens AF focus 10 times from closest focus distance. Then 10 times from infinity. Report your findings back here with pictures if needed, and we can analyse from there.
Thanks for the help! I took your advice and did more stringent testing, and since adjusting the focus, I've have been obtaining much better images in the field. My focus adjustment resulted in about the same as what I had originally "concluded", so that gave me some confidence. Also, I timed the autofocusing for each focusing test and I fear that the SDM motor may be starting to weaken, as they were not as consistent as I was expecting. Sometimes snappy, sometimes quite slow, focusing just a bit slower when I first turn it on. I don't think I would have ever noticed if I didn't do this with so much attention paid, so I'm not going to worry about that aspect of it for now.
I also have been doing some digging in my photo library to see if there has been a common thread in pictures I'm not thrilled with, and it seems that I have been too confident in my handholding capabilities and using too slow of a shutter speed. I see that I have more keepers in my library if the shutter speed is above 1/400. I'm usually walking/hiking while using it, so my unsteady hands and movement from physical activity exasperated my blurry issues separate from issues inherent to the lens.
More often than not, at least for me, its not the arrow but the archer
