02-10-2020, 09:53 PM   #1
Question regarding electronic shutter on KP
Hi, would someone help me find out what happens in the following cases?
1. When you take a single photo using electronic shutter on KP, does the shutter count go up 1?
2. When you take a continuous burst of 10 photos using the electronic shutter on KP, does the shutter count go up 1? Or 10?
The reason why I ask is because the mechanical shutter should actuate only once in each case; someone was explaining somewhere that the shutter count you see in the Exif data is the number of shots taken using the mechanical shutter, so I wanted to know what happens when using the electronic shutter.
This question is only relevant to KP because as far as I know, KP is the only pentax camera that keeps the mirror up and shutter open while shooting in burst mode with the electronic shutter.
Thank you!
02-11-2020, 12:38 AM - 1 Like   #2
I believe it's 1 for every click. The shutter still moves each time, just not the mirror.
02-11-2020, 04:26 AM   #3
That would be my guess too, but could you confirm by actually shooting and checking the Exif data? I know this is a lot to ask, so please only help if you are also curious about this (or feeling exceptionally generous).
I'm not that curious about single shots because I know that the whole cycle is actuated once just like using the mechanical shutter. I am particularly curious about what happens during a burst shot using electronic shutter, in which -- I'm pretty sure -- the mirror and the shutter only move at the beginning and end of the entire burst -- not each shot.
[Edited] Wait, are you saying that the shutter moves before and after each shot during a burst as well? That might have to do with a setting of some sort. In the following video, you can see that the KP is taking multiple shots without actuating anything mechanical in between the shots (sounds only at the beginning and end of the burst).
02-11-2020, 06:06 AM - 2 Likes   #4
rogerstg's Avatar
QuoteOriginally posted by PentaMiCL Quote
I just checked. It's one per shot whether using MS or ES. Taking a burst with ES is a little weird, there's no noise so you have no idea how many shots have been fired until you look at the photos taken. For this test, I took 8 shots.
02-11-2020, 01:31 PM   #5
QuoteOriginally posted by rogerstg Quote
Hi, thank you for checking. Just to reconfirm, when you took the 8 shots using burst mode, the shutter count increased 8?
I was just wondering about this because the shutter count is sometimes used to estimate the general wear of the internals, but I would assume people with a very high shutter count using KP may likely have been using ES (burst) for in-camera averaging and time-lapse, which don't actually wear down the mechanical shutter.
Thank you so much for your insight!
02-11-2020, 04:37 PM   #6
rogerstg's Avatar
Yes it did
02-11-2020, 07:20 PM - 1 Like   #7
Yes it did
Thanks for the confirmation. With your answer, I was originally going to go with the copy that had 50,000 shutter count, which was 40 bucks or so cheaper, in hopes that the previous owner simply used the ES-burst (or time-lapse) a lot. However, I noticed that the body had significantly more wear as well so I just went with the prettier one with an added bonus of a low shutter count.
At any rate, I did purchase a used KP and am waiting for it to arrive. Looking forward to hit 1 million in shutter count, then.
burst, count, kp, pentax kp, question, shutter
KP vs K-70 - to KP or not to KP, that is the question OldChE Pentax DSLR Discussion 28 11-02-2019 05:29 AM
Can you use the electronic shutter on the KP with the intervalometer? bladerunner6 Pentax KP 3 10-01-2018 03:30 PM
Rolling shutter effect when using electronic shutter D1N0 Pentax K-1 10 07-27-2018 02:37 PM
Question regarding electronic shutter.. eccs19 Pentax K-1 17 02-08-2018 01:13 PM
Question on KP Electronic Shutter and Live View th1952 Pentax KP 5 12-09-2017 08:49 AM
All times are GMT -7. The time now is 01:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
