I figured out what was going on. When I push the AF Mode, the dial on the front of the camera changes the AF mode (AF S, AF C, AF A) and the dial on the back of the camera changes the focus points (27, 9, spot, etc). You can also change the focus points through the menu. Not sure if AF Mode using the dial is the default setup or if the person I bought this from recently had it set up that way. Anyway, I figured it out.
Now I just need to figure out which mode is best for my kids soccer and basketball games - when they are able to start playing again...
---------- Post added 03-26-20 at 06:50 PM ----------
Quote: Another benefit of AF.C is linked to the AF points themselves. You can use just the centre point as in AF.S: many people do. However there’s additional functionality using the 27 points. In the auto mode, the camera selects what it wants to focus on - this was true right back to my *istDS. But in the select mode in AF.C (I use the centre square of 25 cross-type points), if you activate AF with the subject under the centre red square and continue to hold the AF button then the AF will track the subject across the focus points. Not perfect, not predictive but better than many think.
So you're saying that if I have it in AF C mode and then SEL mode with the red dot in the center, if I focus on a moving object (e.g soccer player), it should maintain focus on that player?
