04-24-2020, 10:46 AM   #1
USB Fail
I have tried numerous USB cables, but I cannot connect my KP to my laptop running Windows 10.
Problem solved! I found a cable that works; an AmazonBasics!!!
Thanks to all for your help and suggestions.
David
04-24-2020, 11:00 AM   #2
Not a Number's Avatar
There's a setting in the KP menu for USB connection type. Try changing that.
04-24-2020, 12:47 PM   #3
Otis Memorial Pentaxian
QuoteOriginally posted by doc58bc Quote
With the camera USB setting on MSC and a formatted SD card in the camera and computer booted, turn the camera off and connect the cables. When the camera is turned on, it should be recognized as a removable USB drive. Before turning the camera back off, be sure and remove/eject the drive from your computer. Be sure your battery charge is up or use the optional AC power adapter to make sure the camera does not lose power while connected to the computer.
04-24-2020, 03:07 PM   #4
Thanks Steve, but the computer still does not recognize the camera!
David
04-24-2020, 03:58 PM   #5
Have you checked in "Device Manager" to see if the computer knows "something" is connected but simply doesn't recognise it, or even Explorer or "My Computer" to see if the computer, for whatever reason, is recognising the camera but simply not giving you a notification? The "Autoplay" feature can be a little finicky sometimes. Also just possible the computer doesn't recognise the card in the camera, try a different card, perhaps? Don't suppose you've got access to another computer to help eliminate options?
Good luck!
04-24-2020, 04:34 PM - 1 Like   #6
paulh's Avatar
I avoid these problems by simply using a usb card reader.
04-24-2020, 05:04 PM   #7
me too using the SD card reader.
Maybe check if the USB slot is damaged? Try different cables on different devices. if it works on different devices but not on your camera, then it is not the cable problem.
Also, I sometimes have problems with USB3 slot after installing updates for windows 10. But USB 2 slots always work. So if you sure it is not the camera, not the cable then it could be USB driver on your computer is messed up or something. Reinstall the USD driver might help.
04-24-2020, 06:00 PM   #8
David
Does the camera recognize the card? There must be a properly formatted card in the default slot.
04-24-2020, 07:30 PM   #9
ramseybuckeye's Avatar
Make sure you are using the right cable and not trying jam one in from an older Pentax camera, it's a micro B cable now.
04-25-2020, 09:34 PM - 1 Like   #10
QuoteOriginally posted by ramseybuckeye Quote
This is an excellent point, one that I did not fully appreciate until this evening. Prior to the K-3, Pentax cameras used proprietary fittings that required Pentax-brand USB cables. Cables that came with a camera made before about 2006 will not work with the newer cameras. The KP uses a generic USB cable with a micro B connector that should look like the one at the bottom of the center column in the diagram below (labeled "Micro B") and should have 5 contact pins:
04-25-2020, 09:40 PM   #11
Also, some cables are for charging only. Those won't work for data.
kp, pentax kp, usb
Nature Feet don't fail me now ! pichaser Post Your Photos! 8 01-02-2020 11:29 AM
Flying Scotsman Fail 2019 At Speed With A Whistle Sunburn General Talk 9 08-01-2019 06:49 AM
USB-3 vs USB-2 on K-3 Pentax Bob Troubleshooting and Beginner Help 10 11-23-2013 07:58 AM
Macro FAIL!! Not Epic, but FAIL... icywarm Photo Critique 3 04-28-2010 05:51 AM
usb mini USB for 20D and K-7 sevee Troubleshooting and Beginner Help 7 08-27-2009 09:01 PM
All times are GMT -7. The time now is 07:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
