Originally posted by noelpolar I have the last model of the sigma in pentax mount... so I'm no use for you there. I did have the mount changed a few years ago to suit the K1.... and only recently the apperture blades were sticking... due to some binding in the mount (I took it apart to see if I could fix it... but no)... so it went back and was replaced... about $130 this time.... so I know they still have mounts with the chamfer to suit the K1. I think would probably be reasonably safe to assume the K1 issues with your model lens (firmware... not mount) would apply to the KP.... but good luck anyhow!
Thanks, Noel, if I buy the KP, one of the first lenses I'll try will be the Sigma. I'll post the outcome in this topic.
---------- Post added 05-08-20 at 13:09 ----------
Originally posted by rogerstg FWIW, both the Sigma 150-500mm F5-6.3 APO DG OS HSM and Sigma 50-500mm F4.5-6.3 DG OS HSM work fine with my KP. They were developed well before the KP and in the similar, overlapping time frame as your lens.
Thanks, Roger! Keeping my fingers crossed (and I forgot to mention in my opening post that I have a Sigma 150-500 as well
---------- Post added 05-08-20 at 13:21 ----------
Originally posted by mikesbike I don't have the Sigma 70-200mm lens in question, but I do have 2 Sigma EX DC HSM lenses, the 17-50mm f/2.8, which works on the KP just fine, and the 10-20mm f/3.5, which in fact is on one of my KP bodies right at this moment and has been perfectly fine also.
I am trying to theorize why the problems with the K-1. Obviously, the mounting opening and configurations would be different as a FF model vs. APS-C. The K-1 and KP are related in design of controls, but in every other way I know of, they are different animals. If one could find out what the nature was regarding the firmware update, it might shed some light on why it was necessary with the K-1 and not with other Pentax camera bodies. Maybe Ricoh/Pentax would know.
Thanks, Mike, that sounds hopeful.
I'm a-technical, so I've been assuming all along that it probably had something to do with the newer Pentax bodies. On the other hand, it might be due to the difference in FF vs APS-C only, in which case there shouldn't be a problem with the Sigma and the KP. And yes, I'd love to know why the alteration on the K-1 was needed. It's quite frustrating that there doesn't seem to be an extensive list of lenses that will work, but that's probably taking it too far considering the vast number of lenses around. I found that there's hardly anything listed on the Sigma site either and as they're not supporting Pentax bodies anymore, that will likely not change any time soon.
