Originally posted by lidy Okay, I understand that (I think), You're saying that the time you can set in the Menu to switch off the display, is too long for you? You want to be able to switch it off immediately, and that's when you use this. Am I right?
It doesn't appear to me kypfer is complaining about anything, just finding this feature to be valuable.
---------- Post added 05-14-20 at 04:17 PM ----------
Originally posted by rogerstg Ahh, now I understand the OP's dilemma. OP looked at the screen display selection as an on/off switch as opposed to a "what to display" selection.
Exactly. That is what this screen is for- to select the type of display screen to be used. Selecting "off" means just that- a blank display screen. Selecting the first option will deliver the standard display screen. However, I just checked, and if turning the camera off then on, even though having previously selected screen "off" it will indeed come back on anyway just by turning the camera back on.
A similar thing if one uses the info screen to access the quick adjustments screen. If one then turns the camera off, that will exit this screen and the standard screen will be back. But if one selects the type of info displayed, including none, when pertaining to the preview screen, that choice will remain even when turing off the camera.
