06-01-2020, 09:07 AM   #1
Katfsh's Avatar
on board flash stopped working
can this be fixed?
06-01-2020, 12:24 PM   #2
Otis Memorial Pentaxian
Are you set to Auto Flash Discharge? If so, the flash will only work under dim conditions.
06-02-2020, 12:23 AM   #3
calsan's Avatar
A few things could have gone wrong. Is the flash bulb kind of brown? Blown bulb. More likely, the circuit board for the flash has died. Can be serviced as it's a separate circuit board to the main camera board.
06-02-2020, 05:44 PM - 1 Like   #4
Wingincamera's Avatar
Are you using the electronic shutter? Flash will not work with it.
06-02-2020, 08:09 PM   #5
Katfsh's Avatar
its blown i can see it now if look closely its looks like a fuse when it blows
06-02-2020, 08:14 PM   #6
Katfsh's Avatar
here is a picture of it
PENTAX K-1 Mark II  Photo
06-03-2020, 01:12 AM   #7
calsan's Avatar
That's off for repair then...
Pentax Repair Facilities (Wordwide listing) - PentaxForums.com
06-03-2020, 09:49 AM   #8
It's pretty rare for a flash to go out.
Just curious if you used flash a lot or not much at all Katfsh?
06-04-2020, 04:38 PM   #9
Katfsh's Avatar
I used it a lot.....just about every time i used the camera....And you live fairly close by i see..i am in dixon!
07-01-2020, 11:56 AM   #10
The flash output can be adjusted in steps from -2 EV to +1 EV. If you had the flash constantly set in the plus range could that have over-stressed it?
07-04-2020, 04:20 AM   #11
A similar thing happened to me years ago with my first Pentax dslr, the *istDL. What happened with me was when testing the camera one day I was firing off flash shots in rapid succession which apparently stressed the capacitor causing it to fail. It was an easy repair for the shop, just replaced with a new one. Lesson learned.
board flash, kp, pentax kp
645z Lightroom tether stopped working after newest LR Mac update Akrat Pentax Medium Format 3 02-16-2020 01:05 PM
Pentax IstDs: left side buttons stopped working heki Troubleshooting and Beginner Help 6 10-08-2019 11:18 AM
K30 pop up flash stopped working? stillshot2 Pentax K-30 & K-50 20 03-12-2014 08:23 AM
K-r: built-in flash stopped working after using external flash wedge Troubleshooting and Beginner Help 7 01-12-2014 07:57 PM
Flash just stopped working? Eruditass Flashes, Lighting, and Studio 9 07-01-2010 05:49 AM
All times are GMT -7. The time now is 12:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
