06-15-2020, 08:45 AM   #1
Questions when using Back Button Focus & locking AE when AF & linking AE to AF point
Questions when using Back Button Focus (bbf) & locking AE when AF and linking AE to AF point
KP camera refer to menu C1 items 5 & 6.
for bbf is this correct?
• When AE-L with AF locked is on (menu C1 item 6), exposure occurs and is locked when bbf is pressed
• When AE-L with AF locked is off, exposure occurs when bbf is pressed and again when shutter is pressed
• When AE-L with AF locked is off, if desired to lock AE, one of the FX buttons would have to be assigned to AE-L
• Meter operating time is as long as bbf is pressed? or
• Meter operating time is whatever time is set in the menu (KP camera menu C1 item 3)
• Metering time is not affected by AFC
• When AE & AF point are linked (menu C1 item 5), it overrides AE metering point (record menu item 1) which might be set to multi segment, center weighted or spot
If it does override it, why does AE metering (point) in record menu item 1 appear active. Should this be grayed out?
When shooting bif and most everything else I have been using AE & AF point linked and AE-L with AF locked and using spot AF and bbf. After thinking about composing the above questions I realize even though it might be good for bif it could be better if I turn these off in my user settings for artwork, landscape etc.
thanks, Bernie
ae, ae-l, af, bbf, bif, c1, item, kp, linking ae to af point, locking ae when af, menu, pentax kp, questions, time
K5 Segment Metering with AE-L with AF Locked set ON, AE linked to AF Point set ON WightWalker Pentax K-5 14 12-05-2012 10:30 AM
Linking Spot Metering to AF Point radeg Pentax K-5 4 11-26-2012 06:05 AM
Linking AE to AF Point during Multi-Segment Metering i_trax Pentax DSLR Discussion 3 05-21-2012 05:28 AM
Linking AF point and AE during multi-seg metering geckogrin Pentax DSLR Discussion 3 08-21-2010 07:59 PM
BBF Button do we have one on K7 waydon64 Pentax DSLR Discussion 7 06-02-2010 10:12 AM
All times are GMT -7. The time now is 02:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
