Originally posted by johnny9fingers Hello,
Can you set the KP to give focus confirmation by the focus point lighting up when focus is achieved, using an AF lens like the the 20-40 Ltd in manual focus mode?
If so, please tell me how to set that up.
Thanks,
John
Not wanting to directly contradict some of the advice above, but focus confirmation works in MF mode just fine, with no hoops to jump through unless one is set up for back-button focus.
What doesn't work is trying to use other than the center point for focus confirm. Edit: Well! That goes to show what never using other than center point does to one's brain. The correction is that the active focus point will be indicated if your rack focus, even when using focus confirm. To use focus confirm, set the camera to MF and half-press the shutter.
For further clarification, the lighting the focus point only indicates that it is active. The green hexagon indicates best focus.
