Originally posted by Pugamu Glad to find this forum. I’ve had a KP for a while but I have not tried pixel shift. What software do I need and what is the workflow? I have a Mac and Adobe Lightroom. Thanks!
Hey Pugamu, it's true that no special software is required. The KP can process in camera, but this means you lose the ability to edit the raw file in post processing. Sometimes this is ok, sometimes it is not. It will depend on what you like to do for your normal workflow.
Lightroom can import pixelshift files, but it does NOT handle motion correction in them. Any movement (wind, water, etc.) and you'll have some odd artifacts (the KP does some motion correction in camera but it is often not perfect). They often show up as green/purple static. The software that comes with the KP (I think it's DCU) can handle pixel shift images and motion correction. You can run it on Mac. I found this software quite slow. I've recently been using RawTherapee instead. This is also available (free) for Mac and Windows. It's a pretty powerful tool, but not very intuitive to use (my opinion, anyway). Whether you use DCU or RawTherapee to handle RAW motion correction, you then have the option to export the image as a 16 bit TIFF and import that into lightroom to finish processing as you see fit. Of course, be aware that processing a TIFF in lightroom isn't quite the same as a DNG. You'll lose the ability to select Lightroom color profiles and a few other things. So you may want to incorporate color temp adjustments into the RawTherapee or DCU part of the workflow.
I'm guessing some people here will have a different workflow and it would be interesting to hear it! Let us know what works for you.
