07-10-2020, 02:27 AM   #1
K2 to K50's Avatar
AF position on LCD Display
I have been playing around with customising the U1 to U5 settings etc recently as I become more familiar with the huge feature set of the KP. I have also been playing a little with Live View, and working mainly in TAV mode.
Recently I have done something in the U2 settings that controls the display on the LCD, so that the Four-way controller is being used to reposition the focus point, instead of activating ISO, Flash, WB etc. I have scrolled through all the menus to try and determine which setting has done this, have looked though the manual, through the KP eBook, and even conducted searches in the forum with LCD, LCD Display as search key words.
I am sure the answer is staring me in the face somewhere, but cannot for the life of me find it.
My aim is to eventually have:
U1 as my go to for fast moving, birds/flying things in flight subjects - (1/1000 shutter speed, moderate DOF (about 7.1 to 9, when using my 55-300mm PLM lens), continuous shooting, AF-C etc. ISO on auto, SR on)
U2 for general wildlife shooting hand-held - (1/400 shutter speed, F8, ISO floating, single-shot, AF-S etc, SR on.)
U3 Tripod macro - (1/100, F10, ISO auto, Shake Reduction OFF) (Usually with the 100mm F2.8 macro lens, but occasionally the 55-300mm PLM lens)
But, as I said, something in U2 settings is setting the four-way controller to moving the AF point around, instead allowing the arrows to move around the general LCD display area, or allowing ISO WB, etc to be activated.
So......HELP
As an aside, if anyone has any suggestions for customising other settings for each of these intended U1, U2, U3 functions, I would be pleased to receive them.
07-10-2020, 02:48 AM   #2
maw
maw's Avatar
QuoteOriginally posted by K2 to K50 Quote
I have been playing around with customising the U1 to U5 settings etc recently as I become more familiar with the huge feature set of the KP. I have also been playing a little with Live View, and working mainly in TAV mode....
There are other tabs, you can have a look and redial the user modes (did you know you can also rename them?).
The PENTAX Hyper Control system
07-10-2020, 02:56 AM   #3
pjv
Otis Memorial Pentaxian
pjv's Avatar
Hi Peter, I think you might find what you are looking for on pages 60 & 61 in your manual. Hope so. Good luck mate.
07-10-2020, 06:18 AM   #4
Larrymc's Avatar
So......HELP
Write down all of the settings you want to use in U2 then set the mode dial to TV mode then set up each function you want to use then re-save what you have set up as U2. No use hunting for what you are looking for to turn off. Its much quicker to do it this way.
07-10-2020, 06:19 AM   #5
K2 to K50's Avatar
QuoteOriginally posted by pjv Quote
Thanks pjv: you got it in one!!! The old "Press and hold the OK" trick 99!!
07-10-2020, 06:24 AM   #6
pjv
pjv's Avatar
Glad to help mate.
07-10-2020, 06:24 AM   #7
K2 to K50's Avatar
QuoteOriginally posted by maw Quote
Yep,thanks maw - already into that. Hope there will be no more need to remember to set Shake Reduction back on when switching from tripod to hand-held, for starters!!!
EDIT: Gleep - now, when I take the camera of the tripod, I have to remember to switch from U3 to U2 or U1!!! And just yesterday, took two pics before remembering to do that!!!!
auto, display, iso, kp, lcd, pentax kp, settings, shutter, sr, u2
K-1 LCD display won't turn on for a few minutes (after pixel shift mode) e_nogueras Troubleshooting and Beginner Help 7 12-19-2019 06:54 AM
No LCD display Kenner Troubleshooting and Beginner Help 4 12-15-2019 09:37 PM
Pentax Super Program - No display on LCD, Shutter at same speed HWH Pentax Film SLR Discussion 10 02-23-2019 11:47 AM
unable to display image on back display Starwars50 Pentax K-3 4 06-24-2015 02:48 AM
K10D GX10 CCD Position Adjust (AF adjust) kevbirder Pentax DSLR Discussion 10 09-22-2011 02:35 PM
All times are GMT -7. The time now is 04:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
