Originally posted by Sandy Hancock It's nearly two years ago now, but if I recall correctly, I used back button AFC, 9 point select, and mostly single shot rather than spray and pray.
Thanks! I still don't really get why there's a difference between the back button AFC and the shutter release.
By the way, the colour in the Toucan makes it look artificial. I'm sure it's real, but the colours are so intense that it's hard to believe something like that can exist in nature. I'd love to see one of those in nature too!
---------- Post added 30-08-20 at 12:28 AM ----------
Originally posted by dlh While that's certainly true, the question is, "does it matter?". I've read where folks complain that the light coming in through a FF lens is too widely dispersed for the smaller sensor resulting in fuzzy images. I haven't observed that, myself, with any FF lens.
It sounds counter-intuitive considering that the FF sees more of the lens FOV. Surely an APS-C body on a FF lens is seeing the sharpest part of the FOV?
Quote: And that lens in particular is soooo sharp you have to watch out you don't cut yourself on it. So while there are theoretical reasons why its performance on an APS-C body is sub-optimal, that, to me, is a big, "who cares?", because it makes no practical difference. Sort of like the woman at the end of the long hallway your calculus teacher told you about. True, I get, well, wider and taller pictures with that lens out of the K-1, but I really do like it on the KP, particularly for back-yard bird photography, since I crop such pictures a lot anyway, and only the area covered by the APS-C sensor matters. It may be that the higher pixel density on the KP sensor would make a big difference from how people experience their results with that lens in conjunction with a K-70 or K-3.
In terms of the K-new, my expectation is that it will be able to take advantage of the resolution in the DFA 150-450 which the K3 can't use. I'm hoping that the reduced noise in the KP is also seen in the K-new. The reason for my post though, was to get an idea of whether the lens achieved focus faster and more reliably on the KP as well as improved behaviour with AFC. I guess I'm also curious how it performs on the K1 (in terms of speed to lock etc), but I'm not keen on a FF body because I actually like the extra reach of APS-C, even if perhaps it's partially an illusion.
