Scenario : Camera (KP) is switched on but has gone into "Auto Power Off" mode (p.42 in the manual).
To reactivate the camera I just need to touch (half-press) the shutter button and the metering springs into life, but the autofocus doesn't become available for some noticeable time (half second or more?) later, unless I release then half-press the shutter button a second time.
I'm learning to live with this simply because my previous solution, of not enabling 'Auto Power Off', had left me with an embarrassingly flat battery once too often. (yes, I carry a spare
The annoying thing is that this "double-press" sequence is only necessary on my KP. On my K-70 and earlier cameras the autofocus system wakes up with the metering and is available virtually instantaneously.
Is there some option in the extensive menu system that I've managed to miss which affects this functionality? I've even sat with the KP and the K-70 side-by-side (both cameras have the latest v.1.11 firmware) going through the menus comparing like with like where appropriate and can't see any differences
As always, constructive comments and solutions (if possible) will be appreciated
