Originally posted by normhead The 18-135 was designed for 14-16 MP cameras.
Many very fine lenses were designed around this time and even a long time before, but the DA 18-135mm was not specifically designed to match 14-16mp sensors, that or less is what was available. The lenses were designed to be the best possible for the design goals of lens size, focal length, and lens type. As to being inadequate to match well with higher resolution camera designs since, I found that not to be the case. I was using the DA !8-135mm with my 12 mp K-r as well as my 14.6 K20D even before I got a K-5. I noticed the superior image quality of the K-5, and did so when using this lens as well as with the excellence of the DA Limited prime lenses which were designed before the DA 18-135mm. Then again I noticed improved image quality when I got my KP- again even when using my DA 18-135mm as well as my Limited lenses designed long before. These lenses were not a limiting factor for the camera to demonstrate improvement.
---------- Post added 10-13-20 at 06:01 PM ----------
Originally posted by normhead particularly on the edges, where the 16-85 is better.
This is what has been shown as true, particularly if compared between 60-85mm. However, though for some purposes this can be meaningful to some, the more usual occurrence as the lens is zoomed into a more tele range, the edges become less important, while the central area becomes were the subject of interest lies. In independent tests, the DA 18-135mm proved to have better resolution readings overall at various focal lengths- in the central area, and comparable at the edges even to the DA 16-85mm from 18-through 50mm, especially when at f/5.6 and onward. Then, as zooming farther into tele, while the DA 16-85mm came out easily better at the edges, the DA 18-135mm hangs onto its central area resolution at 85mm (and beyond) far better than does the DA 16-85mm!
So the DA 18-135mm's central area is sharper, even going into the tele range where usually the edges become much less of an issue. The test reviewers should recognize this fact, but often they give too much credence to edge performance at tele settings, or resolution even in corners being (to me) overemphasized in their rating of the lens. Perhaps important for some special need or other, but in general a non-issue.
The DA 16-85mm is a fine lens- I am not in any way saying it is not. But like anything it has its strengths- mainly from what I've seen being its 16mm wider angle, and its edge performance- particularly beyond 50mm to its 85mm maximum. It is also a costlier, larger, and bulkier lens than the DA 18-135mm, and my impression has been the AF of the DA 18-135mm is faster, being among the best of Pentax lenses.
