Originally posted by stevebrot Smart Function dial under AE.
That means taking my eye away from the OVF and fiddling with two, separate dials, of which I generally prefer to leave as ISO. It's almost quicker and easier to assign it under the INFO button and switch it that way, if I'm already breaking my composition work flow with the OVF anyway. A single press of a single button, like on the pro bodies, would be ideal.
Quote: Are you meaning a choice between those three? I don't have access to a KP, but AE Lock on other models stays enabled until either second press, green button press, exponsure mode change, meter off, of power on/off.
Yes, so it operates like my K3. I edited my post because I think I found the setting in the menu: (C)ustom menu, page 1, third line down says "Meter Operating Time". I thought this was specifically for how long it might meter in general use, like BBF with AF.C, but I changed the default setting of 10 seconds to setting #4, "Continue" ("Measures exposure until the shutter is released or the camera is turned off"), which doesn't sound like it should work, but at least the AE-L "star" indicator stays lit now, until I either press the button I've assigned to it or I turn the camera off. More experimentation is needed, but that *seems* to have done the trick!
---------- Post added 01-10-21 at 12:05 PM ----------
Originally posted by BigMackCam You might want to post this in the Product Suggestions & Feedback forum.
That said, it hasn't been Ricoh policy (nor Hoya's before that) to add things like this to firmware. Bug fixes, stability and performance improvements are more typical. Still, there's no harm in asking, I guess - though since the KP is now four years old and the last firmware was released in mid 2019, I doubt you'll see any more updates - except, perhaps, for compatibility with new lenses...
Yeah, I know. The post was more just wishful thinking, like a message in a bottle, that might at least bring up some suggestions from other users.
