As a new KP owner I have also been experimenting with the pixel shifting functionality and my experience so far is as follows:
- the improvement is very subtle and not readily seen until one zooms in to a very high level and the role of individual pixels is readily evident.
- its harder to see in some images than others and not always apparent. Very fine details, not masked by motion, lens softness, camera instability need to be present.
- one of the biggest benefits can be improved noise due to the repeated exposures. Even at iso 100, there can be a significant improvement in pixel-level noise especially in shadows.
- when patterns, textures and straight lines approach the level of a few pixels in size the PS functionality can be seen to correct false pixel colours and locations
Here's an example of some crops of an old pottery plate I found in Peru with intricate coloured patterns. Pixel shift on left, normal exposure on the right. Both made with stopped down kit lens from centre of image at iso 100 and jpegs generated in camera.
The noise improvement and correct rendering of fine straight lines in the plate can clearly be seen in the PS image.
To get good results, I've found that careful use with a tripod and remote shutter or self-timer is necessary. I also suspect it works best with sharp lenses at their optimum apertures.
Raw therapee is a great piece of software for processing PS images due to its motion mask and correction features, and the ability to see sub frames or actual bayer filter at the pixel level.
