Originally posted by biz-engineer The Pentax camera has its own definition of 100% , not the same as 100% on computer display.
Yes apparently. I don't know what 100% mean on camera, I believe it's just arbitrary because 100% doesn't correspond to the same magnification on all Pentax cameras, e.g 100% on a K3 doesn't correspond to the same magnification as 100% on a K1, even if both displays are 3" displays.
Of course there are different magnification on different cameras. The magnification depends on the resolution on the sensor, and the resolution on the LCD.
Cameras may using different resolution on the sensor, and may use different resolution on the LCD. So it will not ba a fixed number for all cameras.
But the only Pentax camera that I have used that has a 100% view setting is K3/K3 II (8.3x).
Are you sure that K1 has a 100% view setting? I doubt that it would translate into an even number such as 10x.
Edit: It seems that both K3 and K1 use a 720x480 pixel displays.
K3 resolution: 6016 x 4000 pixels
K1 resolution: 7360 x 4912 pixels
K3 6016/720 (1:1 pixels, 100%) = 8,35x
K1 7360/720 (1:1 pixels, 100%) = 10,22x
So if 10x in K1 is a 100% view, the actual magnification is 10.22x
