Originally posted by Kiddo70 I can get get the images very close just by compensating another -0.30 of a stop.
If the images then look quite the same, and one not brighter than the other, it is possible the K-70's exposure is turning out a bit under that of the KP. The KP's metering system is one of its advancements. The other Pentax DSLR models I have owned and some I still have and use, are prone to some degree of under-exposure. Not so at all with the K-r, nor with the KP, and very little with the K-5 IIs and barely so or not enough to be noticeable with the K-S2. So if dropping exposure by -.3 with the KP does what you are looking for, that's a very easy matter. However, as lighting becomes dimmer, you might consider restoring to normal value. But please do avoid using your camera's mode dial set to "auto". This will cancel use of most of the KP's excellent set of controls, one of its most useful advancements, and will take away access to many adjustments. Then you can easily go into the Custom Image menus to adjust sharpening as I brought to your attention in my post # 9. It is easy to do and worth doing.
---------- Post added 03-19-21 at 11:20 AM ----------
Originally posted by gatorguy The K70 has14-bit RAW, different from the K-S2 but same as the KP. The KS-2 sensor was only 20MP while the K-70 is nearly identical to the KP resolution-wise.
IMO the K-70 is closer to the KP image-wise than it is to the K-S2.
Right indeed! But here we are talking about the JPEG output and color rendition, where the in-camera processor does play a major role. The OP has apparently also noticed some difference in metering for exposure, and the KP's metering is different as well, which can affect color saturation.
