Originally posted by Bertrand3000 I don't really understand this part : ". If I focus in pdaf, switch to mf and dont touch anything, the result is sharp"
How can the picture become sharp by just setting autofocus off? That means that KP was correct at the start?
I understand you are confused. My explanation was not overly precise.
On tripod I make a pdaf pose on 2,8, the result is OK, the same as with cdaf. If I make a pose on 5.6 with pdaf the result is blurry. If I let the pdaf work on 2,8 and then switch to MF, stop down to 5,6 and dont touch the distance scale, then the result is good. My conclusion is that pdaf communication between camera and lens lens is ok on 2,8, but is bad at 5.6. The MF setting removes the bad lens - camera communication, therefore the sharp result
regards
---------- Post added 04-30-21 at 03:12 AM ----------
Originally posted by mikesbike The KP AF system is definitely an overall upgrade for speed and accuracy over Pentax DSLR cameras of the K-30 time frame. However, in this case there seems to be some kind of mis-match with your KP and this Sigma lens. I presume it is a screw-driven lens. I have many of those, but not this Sigma macro lens, and in my case AF has been improved when using my screw-driven lenses with with my KP.
Yet, there is a very recent firmware upgrade (1.3) offered for the KP which addresses better accuracy for use with certain Pentax screw-driven lenses, which might also benefit use with your Sigma lens. I have not yet performed the firmware upgrade, but plan to do so soon.
thanks
The Sigma is screw driven
To be honest: I am afraid of updating. I have read that mistakes the camera get off. One of the things I am afraid of is the battery. It must be fully loaded, but I dont know the condition of my batteries. My third party battries are cheap crap., the KP was bought in 2017, the delivered battery is from 2015, My feeling is that the capacity no more is 100%. Is there an objective test I can make with a multimeter instead of "kitchen tests"
My best update solution may be to drive the long way to Copehagen and pay the dealer.
I have succeded with making troubles out of many easy installations, therefore I am afraid
