Originally posted by Crooski It's not the 55-300mm PLM lens, it's at 300mm f/6.3
Pentax DA 55 - 300 mm Telephoto
---------- Post added 08-30-21 at 02:52 PM ----------
Originally posted by cdw2000 Please identify the lens you were using. The EXIF data only indicates the focal length and aperture for these shots.
Sorry Pentax DA 55 - 300 mm Telephoto
---------- Post added 08-30-21 at 02:54 PM ----------
Originally posted by MikeNArk Nice shots. It helps to have good light.
I agree - with the birds well all I can say is the iight is coming from above. After that its depending on which way the bird happens to be facing. Nothing like posing ur favorite Model!
---------- Post added 08-30-21 at 02:55 PM ----------
I did use Adobe photoshop quite a lot to lighten up the feathers
---------- Post added 08-30-21 at 02:57 PM ----------
Originally posted by Des This is with one of the DA 55-300 f4-5.8 models? Yes it doesn't touch the 55-300 PLM for focus speed.
Good get Mark (esp the first one). Settings? With a bird against the sky I use a preset with AF-C and auto 27 points. It's the only situation in which I use auto AF point selection.
Yes thanks for the compliment. Im thinking about buying the PLM for the speed. The DA takes a great picture but its now meant for moving targets, birds or otherwise.
But it does have this nice feature where once ur in focus, the focus follows the subject otherwise I wouldnt have got this picture.
---------- Post added 08-30-21 at 02:58 PM ----------
Originally posted by bschriver11 I like to stop the aperture down to F/8-F/11 for a greater depth of field. The light can be tricky depending on the angle of the sun for sure.
Im gonna remember that. Thanks for that suggestion.
